Issue to collect data of a page in a notion datatabase
Hello,
I’m trying to extract information from a Notion page that is located inside a table within a database using n8n. However, I’m not sure how to properly set up the workflow to retrieve the data.
Could you please guide me on how to configure the Notion node in n8n to extract this information? Specifically, I need to fetch data from a page inside a database table.
Thanks in advance for your help!
I would check out these workflow examples to show how to integrate with notion in many ways:
@Flora91 you could get what you want by reading this template:Notion knowledge base AI assistant | n8n workflow template.
