Issue with Activating Workflow in n8n - 403 Forbidden Error
Dear n8n Support Team,
I’m encountering an issue with activating a specific workflow in my n8n instance.
The workflow functions perfectly when manually triggered, and all steps work as expected, including the interaction with Airtable.
However, when I attempt to activate it for automatic execution, I receive a 403 Forbidden error.
I would like to use three workflows simultaneously and have all of them active at once.
I am aware that the free plan in n8n limits the number of active workflows.
But even when I deactivate one of the workflows to ensure I have only two active, I still cannot activate the one in question.
The issue persists regardless of which workflow I deactivate.
Could you please help me understand why I am unable to activate this workflow, even when I’m below the active workflow limit?
Is there any setting or configuration that I may have missed?
Thank you for your assistance.
Best regards,
Kamil
Hey @Kamil_Kaczmarek , if your workflow has more than one trigger node (excluding manual) their total number counts towards an active workflow. That is, if you have 5 workflows limit and each has 2 trigger nodes then it counts as 10 workflows.
