Setup:
I have two workflows in n8n:
- Main Workflow (A):
- This workflow passes static data to another workflow using the “Call Another Workflow” node.
- The called workflow is named “Output-Workflow.”
- Output-Workflow (B):
- Runs queries and includes a “Wait” node to delay execution for maximum up to 7 minutes before returning data. Whenever the output received the workflow pass the data to Main Workflow (A)
Issue:
- The expected behavior is that the “Output-Workflow (B)” should wait for the full 7 minutes before sending data back to the Main Workflow (A).
- However, instead of waiting the full duration, the empty data is returned to the Main Workflow within 120 seconds (2 minutes)
Question:
How can I ensure that the “Wait” node in the Output-Workflow holds execution for the max 7 minutes before passing data back to the Main Workflow?
Any suggestions?
Main Workflow:
Output-Workflow:
Full Output completed after 180 sec (Seen in the below screenshot), But I am getting the output as empty in the Main Workflow:
Main Workflow Output:
It is returned as empty in the Main Workflow Output (A).
- n8n version: Version 0.225.2
- Database (default: SQLite): MySQL
- n8n EXECUTIONS_PROCESS setting (default: own, main): own
- Running n8n via (Docker, npm, n8n cloud, desktop app): : docker
- Operating system: Ubuntu 22.04.2 LTS
