I Have an issue with create Active directory with LDAP
When i create it using ldap node , then add
unicodePwd like : Password@123465
userAccountControl : 512 or 66048
Give me this error
0000001F: SvcErr: DSID-031A126C, problem 5003 (WILL_NOT_PERFORM), data 0 Code: 0x35
My Workflow
Running n8n via (Docker):
Operating system: Windows
zynate
July 15, 2025, 3:50pm
2
Use LDAPS (SSL/TLS) – plain LDAP won’t accept unicodePwd
In your LDAP credential, set the host to ldaps://your-dc:636 or enable “Use TLS”/StartTLS.
AD only allows unicodePwd over an encrypted channel.
Format unicodePwd correctly
It must be a quoted UTF-16LE string.
Example JavaScript to generate it:
js
CopyEdit
const pwd = 'Password@123465';
// wrap in quotes, convert to UTF-16LE bytes, then base64
const buf = Buffer.from('"' + pwd + '"', 'utf16le');
return buf.toString('base64');
In the LDAP node’s Attributes section:
php
CopyEdit
unicodePwd: {{ $binaryPwd }} // if you used a Preceding Function to create binaryPwd
Set userAccountControl to a single valid flag
For a normal user: 512
Don’t OR it with other values unless you know they’re needed (e.g. 66048 = NORMAL_ACCOUNT + DONT_EXPIRE_PASSWORD).
Example Workflow Steps
Function node (before LDAP) to compute unicodePwd:
js
CopyEdit
return [{ binary: { pwd: buf } }];
LDAP node → Operation: Create
yaml
CopyEdit
Distinguished Name: CN=John Doe,OU=Users,DC=example,DC=com
Object Class: user
Attributes:
sAMAccountName: jdoe
userPrincipalName: [email protected]
unicodePwd: {{$binary.pwd.data}}
userAccountControl: 512
Ensure “Use TLS” is checked or use ldaps://.
With those three changes—encrypted connection , correct UTF-16LE quoted unicodePwd , and a single valid userAccountControl —the “WILL_NOT_PERFORM” error will disappear and the AD user will be created successfully.
system
Closed
October 13, 2025, 3:50pm
3
