Issue with creating Google Drive OAuth Credential because callback URL is not a TLD, using a self-hosted n8n on Northflank
Am using a n8n Community Version hosted on Northflank, which generates a callback URL that includes the full subdomain, in addition to the “code.run” domain. However, Google OAuth does not accept the full callback URL.
On the Google OAuth setting page, in the “Authorised Redirect URI” window, I get a “Invalid Redirect: must use a domain that is a valid top private domain” error message.
So, how should i get around this? thanks so much in advance!
  • n8n version: 2.12.3
  • Database (default: SQLite): postgres hosted on supabase
  • n8n EXECUTIONS_PROCESS setting (default: own, main): not applicable
  • Running n8n via (Docker, npm, n8n cloud, desktop app): community version on northflank
Hi @deta Welcome!
As expected, in google redirect URL field they ask for a authorized domain in the OAuth consent screen to be a top private domain, you can try first go in google cloud console > APIs & services > OAuth consent screen > authorized domains and there enter that code.run then in authorized redirect URIs, you can still use the full callback URL:
https://yourapp.something.code.run/rest/oauth2-credential/callback
Also make sure that in your n8n env the webhook URL is set to your full domain WEBHOOK_URL=https://yourapp.something.code.run something like that and then let me know if this works as this should cause most of the times this is what causes that error.
Thank you for your really fast reply. But unfortunately, it does not work.
  1. I did miss out adding the “code.run” to the Authorised Domains. [I have added that now.]
  2. But when i go back the Authorised Redirect URI, i cannot add my full callback URL. [Same Error that my URL is not a TLD]
Is it an issue if my Callback URL is as 'weird’ as this?
https://p02--n8n-xzx-yyyy.code.run/rest/oauth2-credential/callback
@deta Now it is confirmed that google does not see that URL as a valid URI, there can be workarounds but still this is the truth that you cannot add that URL in redirect URL field as google would not accept that as google sees it as maybe not trusted, if you can then try to map a custom domain if possible so that the URL does not look like that, but that would be a very long processs so what i would say that try running an Ngrok tunnel for that n8n URL and there add it as a redirect…
oooookay. thanks anyhow! Let me try to figure this out.
yeah google won’t budge on this — code.run subdomains just don’t pass their TLD validation. the ngrok approach anshul mentioned is probably the most practical fix. one thing to keep in mind: update WEBHOOK_URL in your n8n env to the ngrok URL, otherwise the callback goes to the wrong place. and if northflank lets you map a custom domain, that’s the cleaner long-term solution since you wont have to update the ngrok URL every time it changes.
ok - thanks! let me try other alternatives now! thanks for the gotcha on the WEBHOOK_URL too!
Decided to go with getting a domain. that has solved this problem! tks everyone :slight_smile:
Awesome, glad you got it working! Getting a custom domain sorted is definitely the cleanest path forward anyway :+1:
makes sense — custom domain is the clean fix for OAuth callback requirements. glad it worked out!
