Issue with N8N Audit after updating - fixed
Audit not working anymore in professional cloud version. I didn’t change anything but my workflow broke after upgrade I think two versions back.
I don’t think many people use this feature but we did.
“errorMessage”: “The resource you are requesting could not be found”,
“errorDescription”: “Request failed with status code 404”,
“errorDetails”: {
“rawErrorMessage”: [
“httpCode”: “404”
“n8nDetails”: {
“nodeName”: “n8n”,
“nodeType”: “n8n-nodes-base.n8n”,
“nodeVersion”: 1,
“resource”: “audit”,
“operation”: “generate”,
“itemIndex”: 0,
“runIndex”: 0,
“time”: “4/2/2025, 11:08:50 AM”,
“n8nVersion”: “1.85.4 (Cloud)”,
“stackTrace”: [
“NodeApiError: The resource you are requesting could not be found”,
" at ExecuteSingleContext.httpRequestWithAuthentication (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/request-helper-functions.js:946:15)“,
" at processTicksAndRejections (node:internal/process/task_queues:95:5)”,
" at ExecuteSingleContext.httpRequestWithAuthentication (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/node-execution-context/utils/request-helper-functions.js:1143:20)“,
" at RoutingNode.rawRoutingRequest (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/routing-node.js:319:29)”,
" at RoutingNode.makeRequest (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/routing-node.js:406:28)“,
" at async Promise.allSettled (index 0)”,
" at RoutingNode.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/routing-node.js:139:35)“,
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:733:26)”,
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:913:51",
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:1246:20"
    n8n cloud
Never mind was a typo in the url of the credential.
