I’m encountering an issue with the OAuth authentication for Netatmo within n8n. The initial authentication process completes successfully, allowing me to access the necessary data. However, after approximately 3 hours, the access token expires, and authentication subsequently fails. The token does not refresh automatically, which disrupts the workflow and prevents it from functioning as intended.
When the token expires, I receive an error through my error email workflow : “Forbidden - perhaps check your credentials?”
Below is an overview of my current workflow setup:
Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
Operating system: Synology NAS
What I’ve Tried So Far
Verified OAuth2 Credentials: Ensured that all OAuth2 credentials are correctly entered and match those provided by Netatmo.
Checked Token Expiry Settings: Reviewed the token expiry settings in both n8n and Netatmo to ensure they align.
Reviewed Logs: Examined n8n logs for any additional error messages or hints about the token refresh failure.
Consulted Netatmo Documentation: Cross-referenced my setup with the official Netatmo OAuth documentation to identify any discrepancies.
Request for Assistance
I’m unsure why the token isn’t refreshing automatically after expiration. Has anyone experienced a similar issue or can provide guidance on enabling automatic token refresh for Netatmo in n8n? Any insights or suggestions would be greatly appreciated!
I need help as I’m still facing issues. I plan to implement my own OAuth 2.0 authentication to verify that the token and refresh token I receive are valid and functioning correctly. Could this issue be related to a parameter configuration on my end, or is it potentially an OAuth 2.0 implementation issue with n8n?
I built my own OAuth 2.0 authentication system with a refresh token, and it works flawlessly! It was the only viable solution I found until this issue is permanently resolved in a future version.
Expirying OAuth issues are always the trickiest to solve. I would imagine it’s not really an easy fix so you may want to look for a freelancer/developer to take a look.
I found these OAuth-related templates in the gallery which might hel.
Thank you for sharing your thoughts and the OAuth-related templates. I wanted to update you that the native OAuth implementation wasn’t handling the refresh token correctly for this specific API. To resolve the issue, I developed a custom OAuth authentication flow that properly utilizes the refresh token—and now it works pretty well!
You seem to have exactly the same problem that I have.
Is it true that your refresh-token only lives 3 hours?
Luckily the refresh-token for my particlar case lasts 45 days.
scripts runs for 3 hours and than “authorisation” problem occured.
when I manualy refresh: access_token, and refresh_token, everything starst again.
Now trying to find some proper way to work with netatmo: authCode (singleUse) / access_token (3-hour expiry) / refresh_token (???)
I have headache from this.
and to be hones to all of you, I cant code - everthing is made by ClaudeSonet.
I understand this, but my skills are not as far as I need for this. So I have to “experiment” a lot.
And because skript runs on Shelly gen2 Pro DualCover, I have to optimise syntax. for me… lots of hard working
Hi there!
I’ve found that post after I googled the hell out. I’m facing the same problem and found no solution. In NodeRed I developed my own solution and store the token and refresh token in the global context. In n8n I noticed there are variables.
Your auth system looks pretty good. Can you provide this as a template?
@bNj I am facing exactly the same issue with MS SharePoint OAuth2 API. May I ask, how you impemented the custom OAuth2 authentication? In case you did that with n8n HTTP Request Node, would you be so kind to share just that particular part?
