Issues configuring n8n in production with cortex
Hi team,
I’m facing some issues while configuring n8n with cortex in production.
Cortex is installed with https.
I have installed Thehive as well but Thehive is working fine.
How can i fix it?
Thanksin advance.
Logs
{“name”:“RequestError”,“message”:“Error: unable to verify the first certificate”,“cause”:{“code”:“UNABLE_TO_VERIFY_LEAF_SIGNATURE”},“error”:{“code”:“UNABLE_TO_VERIFY_LEAF_SIGNATURE”},“options”:{“timeout”:300000,“headers”:{“Authorization”:" Bearer xkUJY5CCMnO6m8YHwKHgyOkCb0ER8qFn"},“method”:“GET”,“uri”:“https://cortex.domain.xxxx.yyy/api/job/222",“json”:true,“simple”:true,“resolveWithFullResponse”:false,"transform2xxOnly”:false}}
This seems to be an issue with how cortex it’s setup. I would ask in the TheHiveProject community if they have one. You can avoid that by setting a env variable according to the link below, but I would not recommend it as the communication would not be secure anymore.
Thank you @RicardoE105 !!!
