Issues in installing n8n-pupeteer node
Hello,
Can anyone help me deploy Puppeteer in the n8n node? I installed node but am unable to install the backend. I am using a self-hosted version via Oracle and Portainer, and since I am a newbie, I can’t install it properly.
Here’s the docu version: GitHub - drudge/n8n-nodes-puppeteer: n8n node for browser automation using Puppeteer
Hi there, could you please verify that you can install it from the settings page?
When you click “Install”, enter “n8n-nodes-puppeteer” and then you should be able to see the node on the canvas
@danougill yes, I already installed this. The problem is for backend. I’m unable to install the libraries and dependencies.
