Issues with Jira Node in n8n - Unable to Fetch Issue Details
Exploring n8n for the first time to work on a POC so please don’t mind if I have missed some details.
When I use the Jira node to fetch issue details in n8n, I receive a sign-in page for Microsoft online services instead of the issue details.
Initially, I was encountering an “Unable to load certificate” error. I managed to bypass this by setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' in my Docker container.
Afterward, I was able to successfully authenticate my Jira credentials in n8n. However, when I tried to use the Jira node to fetch issue details, I received an unexpected response. Instead of the issue details, I received a sign-in page for Microsoft online services.
There is no explicit error message. However, the response from my attempt to fetch issue details is a Microsoft login page, not the expected Jira issue details.
Sign in to your account
  • n8n version: 1.39.1
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Docker Desktop
  • Operating system: MacOs
Hi @TeCoe_POC, thank you for reaching out and we’ll be happy to try and unblock you from working on your poc.
Do you mind sharing a bit of your workflow with us so that we can replicate that behavior?
This all sounds very odd. Do you only encounter that response with the NODE_TLS_REJECT_UNAUTHORIZED environment variable set to 0?
nvm… It was some proxy issue on my workstation. Jira node is working as expected.
