So I am hosting n8n locally using Docker and encountering issues with a Telegram trigger event. The error message indicates that the webhook URL needs to be HTTPS, but my current URL is HTTP. I’ve read the documentation, which suggests setting up a reverse proxy, but I’m unfamiliar with this concept. Can someone provide guidance on how to resolve this issue, thanks.
Thanks, man! I tried Cloudflare, but it was a bit tricky. ngrok worked like a charm after a few tutorials. One thing though, do I need to run the ngrok command in PowerShell every time I restart my PC/server, or is there a way to make it persistent?
