Issues with waiting form
I seem to be having issues where if there is a wait node with a waiting web form submission and there is another wait node any point after the first wait, the submitted form will be error out. It only seems to be a problem if the time is greater than 30 secs.
Can any one else confirm this is a bug? Or is it something I’m doing.
Kind regards
John
Problem loading form.
  • **n8n version: 1.68.1
  • **Database (default: SQLite):SQLite
  • **n8n EXECUTIONS_PROCESS setting (default: own, main): default
  • **Running n8n via (Docker, npm, n8n cloud, desktop app): docker
  • **Operating system: ubuntu 22.04 LTS
I just did a test with an online trial account in the n8n cloud, and it does the same thing.
Can someone confirm this? I had multiple waits in the workflow of previous versions and had no issues.
Hi @jthompson
I believe you’ve also posted this on Github, right?
We’re still looking into it! :eyes:
