It is possible to root data and map the same node, dynamic input tho?
Hello Community,
When I use Switch node I’ll be able to map to different nodes, I would like to know if it’s possible to map to the same node but make one Field dynamic instead of different nodes ?
Thanks
Hi @TheG, the Switch node supports expressions, so can compare data dynamically. What exactly do you have in mind that’s not currently working for you?
