JavaScript code problem!
I try to run the code, but it gives an error. I don’t understand what’s going on. The input value is correct.
Hey @Denis_Praskov, welcome to the community! n8n expects return values always to be in the following format:
  "json": {"key": "value"}
So in your case it would expect
return {"json": {"lastBalance": str}}
You can read more on the data format here. Hope that helps :slight_smile:
Thank you very much, you really helped me out :innocent:
