JavaScript on Code
You can read more about date formats in n8n here https://docs.n8n.io/code/luxon/#if-you-have-a-date-in-a-supported-standard-technical-format
@ rfdepauli Try this solution
Thank you very much, Ruslan_Yanyshyn! I made a few adjustments and it worked perfectly for me! Thank you for all your help and patience!
Now that I realize I left my credentials exposed here. I will generate a new API Token in Z-API. Therefore, perhaps the flow will be interrupted for anyone who comes to follow our conversation from now on!
Thank you very much again, Ruslan!
Welcome Ricardo, I suppose you don’t need Start Node in your workflow since you have Cron node.
Yes! I just left the Star node to perform the tests!
