I’ve bee
I’ve been trying to automate jira issue creation. Creating a simple issue is working.
But as soon as I try to add a custom field or set a component the integration is throwing errors.
What is the error message ?
If I try to add a component to the issue, I cannot even use the component to select or insert one in a working state. The component itself returns the following error: Error fetching options from Jira Software and inserting a known existing component either plain or as an array item I get the following error: additionalFields.componentIds.map is not a function
I tested the Jira integration with a selfhosted and cloud instance. In both cases the same error occures. Manually querying the jira api endpoints is working though.
- n8n version: 2.1.4
- Database (default: SQLite): SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): own
- Operating system: Debian 13
Thank you ahead for your help ![]()
