JSON Code not parsing
Describe the problem/error/question: I am having issues with the HTTP Request (POST) to have my AI Agent reply messages in my business page messenger. It is parsing only 1 of 2 variables, it parses de Sender ID but it does not work with the output of the AI Agent response variable.
What is the error message (if any)? JSON parameter needs to be valid JSON
Please share your workflow {
“nodes”: [
“parameters”: {
“method”: “POST”,
“url”: “=https://graph.facebook.com/v23.0/{{ $(‘Webhook’).item.json.body.entry[0].messaging[0].sender.id }}/messages?access_token=EAAIoj9kkcksBO67oPogLdcoZChF5ucjOAmpL3xXIjVxINClrgTxZB012uUiN8koqtSMjGRvDxY17VvBZA007iMTu5XjJhoGoq7aCnoYAdpDc5bKSjhI5okcBkCr53ZBhH7XGyOZAHbW1hGZAN97TtiFRy903SHknwixzo9uOgdyuPtlXGESKyOmg3BzaA3K4qPVqFYhE3sdQZDZD”,
“sendBody”: true,
“specifyBody”: “json”,
“jsonBody”: “={\n "recipient": {\n "id": "{{ $(‘Webhook’).item.json.body.entry[0].messaging[0].sender.id }}"\n },\n "messaging_type": "RESPONSE",\n "message": {\n "text": "{{ $json.output }}"\n }\n}”,
“options”: {}
“typeVersion”: 4.2,
“position”: [
580,
240
“id”: “501e805b-e6e3-44c4-9308-6981fe8b83b7”,
“name”: “HTTP Request”
“connections”: {},
“pinData”: {},
“meta”: {
“instanceId”: “270427af964f4be02992a919bf4be11cc2bad6dc44b61ac3c637eec5462441c7”
Asked
Error details
Other info
Item Index
0
Node type
n8n-nodes-base.httpRequest
Node version
4.2 (Latest)
n8n version
1.100.1 (Cloud)
Time
7/2/2025, 12:58:54 PM
Stack trace
NodeOperationError: JSON parameter needs to be valid JSON at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@[email protected]_asn1.js@5_1af219c3f47f2a1223ec4ccec249a974/node_modules/n8n-nodes-base/nodes/HttpRequest/V3/HttpRequestV3.node.ts:366:15) at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@[email protected][email protected][email protected][email protected]_/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1193:32) at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@[email protected][email protected][email protected][email protected]_/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1542:38 at processTicksAndRejections (node:internal/process/task_queues:105:5) at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@[email protected][email protected][email protected][email protected]_/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2108:11
HTTP Request
Execute step
Parameters
Settings
Docs
Import cURL
Method
Fixed
Expression
URL
Fixed
Expression
https://graph.facebook.com/v23.0/30798630063084423/messages?access_token=EAAIoj9kkcksBO67oPogLdcoZChF5ucjOAmpL3xXIjVxINClrgTxZB012uUiN8koqtSMjGRvDxY17VvBZA007iMTu5XjJhoGoq7aCnoYAdpDc5bKSjhI5okcBkCr53ZBhH7XGyOZAHbW1hGZAN97TtiFRy903SHknwixzo9uOgdyuPtlXGESKyOmg3BzaA3K4qPVqFYhE3sdQZDZD
Authentication
Send Query Parameters
Send Headers
Send Body
Body Content Type
Fixed
Expression
Specify Body
Fixed
Expression
JSON
Fixed
Expression
“recipient”: {
“id”: “{{ $(‘Webhook’).item.json.body.entry[0].messaging[0].sender.id }}”
“messaging_type”: “RESPONSE”,
“message”: {
“text”: “{{ $json.output }}”
{ “recipient”: { “id”: “30798630063084423” }, “messaging_type”: “RESPONSE”, “message”: { “text”: “¡Hola! ¡Bienvenido/a a nuestra Agencia de IA! Nos especializamos en ofrecer servicios de Inteligencia Artificial, automatización de procesos, desarrollo de SOPs (Procedimientos Operativos Estándar) y capacitación para ayudar a las empresas a optimizar sus operaciones y crecer. ¿En qué puedo ayudarte hoy? ¿Estás interesado/a en conocer más sobre alguno de nuestros servicios o tienes alguna necesidad específica que podamos abordar?” } }
Options
No properties
You can view the raw requests this node makes in your browser’s developer console
I wish this node would…
  • Database (default: SQLite): Default
  • **Running n8n via (Docker, npm, n8n cloud, desktop app): n8n cloud
  • Operating system: Windows 11 Home Single Language
