Hello Teams, I have some questions/issues about an n8n workflow. Here, I’m trying to receive a webhook trigger and send a message to Slack. Everything looks good until I try to send a quoted comment, and it no longer works. Here is an example of that comment:
“Admin user Admin wrote: > Admin user Admin wrote: > > aaaa > > @joeys hello @Jimmy112”
I did a quick Google search, and I think it is caused by escaped characters in JSON? and I check it those character is not illegals in JSON ? correct me if I ware wrong.
n8n version
1.35.0 (Self Hosted)
Stack trace
SyntaxError: Unexpected token in JSON at position 260 at JSON.parse (<anonymous>) at jsonParse (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/utils.js:64:21) at Object.getMessageContent (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Slack/V2/GenericFunctions.js:101:52) at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Slack/V2/SlackV2.node.js:489:78) at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:724:42) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:660:68 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1062:20
- n8n version:1.35.0
- Database (default: SQLite):default
- n8n EXECUTIONS_PROCESS setting (default: own, main):default
- Running n8n via (Docker, npm, n8n cloud, desktop app):Docker-compose
- Operating system:Linux
