I have an input data that as an array for each item. The array may be empty.
json: {
somearray: [],
json: {
somearray: [1,2],
I’m trying to check if the array is empty or not. When I connect IF node and open variable selector, I cannot select the key of the array (“somearray” above) if the array of the first input data is empty. Is that a bug or expected behavior?
That does not happen when the array is not empty.
Also, if I set manually the expression of IF condition as “{{$json[“id”].length}}”, the workflow seems to work fine even when the array is not selectable in variable selector.
"nodes": [
"parameters": {
"conditions": {
"number": [
"value1": "=null {{$json[\"id\"].length}}",
"operation": "smallerEqual"
"name": "IF",
"type": "n8n-nodes-base.if",
"typeVersion": 1,
"position": [
660,
290
"parameters": {},
"name": "Start",
"typeVersion": 1,
"position": [
250,
300
"parameters": {
"functionCode": "return [\n {\n json: {\n id: [1],\n }\n },\n {\n json: {\n id: [1,2],\n }\n }\n];\n\n"
"name": "Function",
"typeVersion": 1,
"position": [
460,
290
"parameters": {
"conditions": {
"number": [
"name": "IF",
"typeVersion": 1,
"position": [
660,
290
"connections": {
"Start": {
"main": [
"node": "Function",
"type": "main",
"index": 0
"Function": {
"main": [
"node": "IF",
"type": "main",
"index": 0
