Is there any recommended way to set up livenessProbe and readinessProbe for worker pods? Worker is not responding to http probes, port 5678 is closed.
Hi @L_S, welcome to the community!
You would need to set the QUEUE_HEALTH_CHECK_ACTIVE
environment variable to enable the /healthz
endpoint.
See QUEUE_HEALTH_CHECK_ACTIVE
env var and use the /healthz
endpoint to check
Thank you, @MutedJam and @pemontto. I missed it out in docs. It is working like a charm!
Containers:
n8n-worker:
Container ID: docker://ccb40f7df19fc03631f4ed26bad92563d2a9e49544276eae29f1c8e9c3c81ae6
Image: n8nio/n8n
Image ID: docker-pullable://n8nio/[email protected]:46482af570333c5110225daebfae850f4591764ace4428433975ee6223a36033
Port: 5678/TCP
Host Port: 0/TCP
Command:
n8n
worker
State: Running
Started: Tue, 25 Oct 2022 09:17:06 +0200
Ready: True
Restart Count: 0
Liveness: http-get http://:5678/healthz delay=0s timeout=1s period=10s #success=1 #failure=3
Readiness: http-get http://:5678/healthz delay=0s timeout=1s period=10s #success=1 #failure=3
