Keap parameters not present for relevant fields
Country code shows up on this screen, when I am in the Address Line field:
But not when I am in the Country Code field:
Why is that and how do I fix this?
Thanks!
Josh
Yes, that looks like a bug.
If you really want to fix it, it would be in the following file: packages/editor-ui/src/components/VariableSelector.vue
If I had more technical skills, I certainly would @jan!
