Hello,
I completed the n8n Level 1 course but I cannot see the Level 1 badge on my community profile.
Here is the results I had
username : Audrey
unique ID : fbb4687d7ebac0393c3d8cc1d95551c0
Could you please help ?
Many thanks
Hey @Audrey Welcome!
I understand the mail says that you have scored 85% in theory, but that is unfortunately wrong, you have scored:
So please consider retaking the test and then just verify it here:
Hi Anshul
62% was the first attempt, I retake the quizz after that and get the results provided on the screenshot.. So I’m very confused now, if I retake the quizz but results aren’t updated, what should I do ? ![]()
Hi @Audrey if you retook the test and the result have not updated, means only 2 things, you have not provided the right unique_id in the test. Again the best move is to retake the test again
and then checking your score there, as if even that does not help we could give you more assistance, but for now retaking is something you can try , just make sure to fill entries carefully.
I try to do it once again by putting only wrong answer, and when I use the link provided to verify my score, it still use the result I had on my first attempt. There must be something wrong
@Audrey understood.
Hey @jamiemadden_n8n this user is struggling with the unique_id not updating to the live score, user receives the mail of passing but the unique_id attached score always stays the same no matter what. His unique_id is: fbb4687d7ebac0393c3d8cc1d95551c0
Thanks for the tag, @Audrey your results have been syncd and badge assigned. Nice work!
cheers,
Jamie.
Thanks everyone ![]()
