Level 1 Certification: Scored 92% and 89% but received "Need to score more than 80%" email
Hello n8n team,
I recently completed the Level 1 certification quizzes. I received an email stating that I scored 92% in the theory section and 89% in the workflow section, which are both well above the 80% passing threshold.
However, the email also included the confusing message: “You need to score more than 80% in both the theory and workflow segments of the quiz” and my certification status does not seem to have updated.
I have attached a screenshot of the email below for reference:
I have already double-checked my n8n instance to ensure that the workflows associated with the test executed successfully without errors.
Could someone please review my submission and help update my certification status?
Hi, :waving_hand: @jbchap
Finish building the workflow according to the course requirements, then send the data to Discord.
Hi @jbchap,
Based on the screenshot you shared, your scores (92% in theory and 89% in workflow) are indeed above the required 80% threshold, so you’ve successfully passed both sections.
However, the certification process also includes a practical validation step, which seems to be the reason your status hasn’t been updated yet. From the message in your email, it looks like the system did not detect:
  • Data being fetched from the provided warehouse dataset URL
  • A notification being sent to the n8n Discord channel
To complete your certification, please make sure you follow these steps carefully:
  1. Use the Webhook URL and Dataset URL provided in your certification registration email
  2. Ensure your workflow correctly fetches data from the dataset.
  3. Add a step to send a notification to the n8n Discord channel as required.
  4. Verify that the workflow executes successfully without errors and all required nodes run properly.
Additionally, double-check the following:
  • The webhook is triggered using the exact URL from the email
  • The dataset is being accessed and processed correctly
  • The Discord node is properly configured and actually sends the message
  • The workflow execution is visible in your execution logs
Once these steps are completed correctly, the system should automatically validate your submission and update your certification status.
Hope this helps!
