Level 1 Course Badge not received
Hello,
I’ve passed the course after signup and used the provided unique ID and same email as my community account.
95bbc288719020602f3fcb6e9eb4395e.
Got the passed email confirmation with scores saying “almost there”. We noticed you haven’t signed up for the course…
Seems like I’m not the only one having this issue.
Could this be resolved and the badge granted?
Thanks
Welcome @Gvdo to the community :tada:
did you sign up before taking the quiz?
Hi @mohamed3nan
Thanks for your reply.
Yes I did sign up before taking the quizz and got my unique ID (used during the hands-on part)
It’s registered with the same email as my community account.
I followed the steps documented on the page you shared to make sure I would receive it.
Hope someone can initiate that manually.
Thanks :pray:t2:
Hmm, I just checked the status here: https://internal.users.n8n.cloud/webhook/course-level-1/verify?id=95bbc288719020602f3fcb6e9eb4395e
If I remember correctly, have you completed the Discord part?
Completely forgot the discord part as it was not part of the quizz scope. I’ll fix that today :ok_hand:
Thanks a lot for the quick feedback.
Appreciate it.
No problem, take your time. On Discord, it should look like this:
It’s done :slight_smile:
Any manual steps remaining to get the badge?
Nice, now as you can see here: https://internal.users.n8n.cloud/webhook/course-level-1/verify?id=95bbc288719020602f3fcb6e9eb4395e
the quiz score is still not updated, If you have some time can you take it again?
Hi again @mohamed3nan
Just did the test again and double checked all information.
I’m using the right ID and provided my communitu username Gvdo.
Still I’m getting the same email message after completion and no badge
I have just sorted this out for you.
Thanks @Jon
Hope I won’t get the same issue with the next ones :slight_smile:
You should be all good, I made some changes to the backend workflows that run it to append or update which was the main cause of this.
Hi @Jon, I seem to be having the same issue where I’ve keyed in my profile ID (Justin_Lim) and completed the tests with passing results but it’s still telling me I’ve not linked my community profile.
https://internal.users.n8n.cloud/webhook/course-level-1/verify?id=e47a0d259fedf18ba5cc8240d078bf38&submit=Submit
Would it be the same root cause? I’ve taken the test again and again (passing) with the correct email and profile name and still having 2 X’s at Theory and Practical.
Thanks!
