Hello,
Your badge has been assigned.
cheers,
Hello,
cheers,
Hello,
You don’t actually need a discord account to get a response from discord to check off notify team. Having a discord account helps you confirm that you’re sending the messages. However if you get the success response from the discord node, you will still get marked as passed.
cheers,
hey, i havent gotten a badge too
here is my unique Id: a3ef491cf7fdcdf1d6f06f537adcc4d9
your assistance is much appreciated
Hi I just took the level 1 quiz 2 times and after that I havent received feedback on how I did, I took the quiz level 1 5+ times now and it seems that the score is stuck on my second try, when using the verification page to confirm.
I have successfully passed the level 2 quiz and received my badge, I just need my level 1 badge and all is well. I would appreciate the help @jamiemadden_n8n , here’s my unique id: 6510690147d5a4972a57a69633890782
Hello,
I checked your answers and the scores are correct. Remember check the questions. Several of them have more than one answer you need to select all of them to pass the question.
cheers,
Hi, again sorry but i think there seems to be a problem with me answering the quiz 1, I have taken the quiz more than 10+ times now and Im sure I would had a passing score. The concern is there is no feedback emailed to me regarding my scores, and when using the verification page to verify my score, the score is stuck on my second attempt score. I tried intentionally taking the wrong answers, just to see the score and still there is no update on the score. My latest attempt would most likely be a passing score I would appreciate the help regarding this issue. Thank you.
Hello,
Your course progress has been updated and verified. Your badge has been assigned.
cheers,
I’ve completed the Level 1 course quiz with:
- Theory: 92%
- Workflow: 100%
All workflow steps completed ✓
My unique course ID: 157b3dd19f3f66aad2c1518ddd704e1e
My community username: malikx
Could you please manually verify and assign my Level 1 badge? Thank you!
Hello n8n Team,
I have successfully completed the n8n Level 1 course by passing both quiz sections, but the system still shows the course as incomplete and I haven’t received my badge.
My unique course ID is: 284d78ccc22585eafc96422075207f2a
Could you please look into this and manually issue the completion badge?
Thank you for your assistance!
Hey @vmadhuvarshi I can see you already have the badges.
Hello @jamiemadden_n8n , @Miliaga ,
I have completed the n8n Level 1 Quiz [Theory Section - 85%, Workflow Section - 100%] but the Badge is not yet received, not any eMail as well on how to showcase on LinkedIn.
Please help.
Thanks & Regards,
Varun Gulati
Hello,
cheers,
Hello sir i also havent recived my level 1 course bandage. Could you please look out ? heres my unique id: Unique ID: ddc84fbde2c28cad8fb9394179d83582
Hello,
cheers,
Hey, @jamiemadden_n8n I have completed levels 1 and 2 both, but still I haven’t received a badge. Also, when I try to verify it, it says “Course Incomplete,” but I have completed it, and I did get mail for level 1. For level 2 i didn’t even got the mail. Please help.
My Unique ID: 1d182379b4d8f3fed88f07ae45421541
I am not seeing any workflow progress for level 1. Please re-run your level 1 workflows to log the progress. I am not seeing any progress or quiz results for level 2. Did you use the same id for both courses?
Got it! Thank you
Bonjour,
Je n’ai pas reçu le mail pour obtenir mon résultat et pourtant c’est validé.
Unique ID: fd15bd0621cf6d4e9cdeede6ee5a5756
Bien cordialement.
Julien.
Hi jamiemadden_n8n,
on the weekend, I finished courses 1 and 2 and can also access the verification for the unique ID 924f8829b38d8c739e9c4eb400a0ffd4.
Can you have a look after the badges here in the community, that are not yet shown?
Best regards,
Bastian
Edit: Updated now my mail address here to that one used for the certification, as I read in one of your replies in another thread.
Edit2: Badge for course 1 is showing now, second one not yet.
Hello,
My unique ID is 4479ba39f78fa0db71870edb689b2967
I recieved this message after successfully completing the n8n course level 1.
It says that i can add this badge on my linkedin profile under Courses section by adding the unique ID I have got, but I am having trouble. When I enter my unique ID, I receive an error message stating that the ID cannot exceed 25 characters.
Could you please resolve this issue so that I can properly display the badge on my profile?
I want to show it off on my profile and it would look credible and real If it has credentials
Best regards,
Meet Dave
