I keep getting 69% on theory and 100% on workflow… I really don’t get it, and I think some of the questions are weirdly worded.
can you tell me which questions I get wrong.
This is going to be the last one of these I do for a while as it does take time to dig out the submissions and go over the answers.
@Phernan Q3 on all attempts then a mix of others
@tonnic Q1 sometimes, Q2 most of the time, Q3 sometimes, Q9 most of the time
At the moment there doesn’t appear to be any issues with the scoring but it is worth noting that if a question has multiple choices and you don’t get all of the options correct that question is marked as incorrect.
Hey @Jon! could you also check my results?
Unique ID: 97ac8abb2df8e9e31ab92ecef1418b65
Hi @Jon. I recently completed the Level One course for the second time, 77% on Theory and 100% on Workflow. My unique id is 8f8cde6b1104f2ed9d72f5c7b32137d6
Would appreciate your help with determining what questions I missed so I can retake the test. Thanks again for your help.
Best,
Joe
Hi, I have them same issue, please check for me.
My Unique ID: c203c21606f5150858c8c83aaa5a1e4e
Thanks.
Hi, i have the same issue, please help.
i think the error It is because the total number of questions is 13 but only 10 are counted, because question number one starts with index 3 and could be counting only from question 3 to 13 although the total number of questions is up to index 16, 10 questions counted => 77%.
Help
Unique id: d87e5386d8830d6d02a635179d2d2c75
Sorry @Jon sorry to bug you with this but could you pleaseee tell me the errors in my most recent quiz results
Unique ID: e1577718459fbfb2b877925dadf9a927
Thank youuuu
Same situation of the question above, I’ve taken the quiz many times, but I can’t seem to score higher than 77 on the theory section, even though I consistently score 100% on the practical exam.
My Unique ID: fd5f4d5a60d49d6fb01a7082a3dbf79c
Thanks!
Jon,
I have the same issue. Can you pls check for me ?
Unique ID: 228815c6f189bba640ef4d7ba28bddf8
@Jon , @n8n I have passed quiz level 1. I would like to know what I did wrong.
Could you help me please?.
My ID is: 6d9808a9114a532b4bdb04d33569b7ad
Thank you in advance.
Alright it looks like it is time to do another one of these ![]()
@poltronieriana Across your attempts you got a few wrong The one you always got wrong was around Trigger nodes, You also got the question about where credentials come from wrong a few times.
@jfleewebmgr Your ID has not taken the course so it is possible that you mixed up emails at some point during the process.
@thang For you it is a just a mix but multiple choice ones got you the most.
@Merlin_R question 3 and 7 you got wrong on all attempts and question 9 on 2 attempts.
@Vidit Questions 1, 3 and 4 gave you the most problems.
@JLacerda 1, 3 and 7 were the commonly incorrect ones.
@Jackson_Tang 1, 3 and 4 were common then a couple of slight variations with some of the others.
@Hugo_Arturo_Zerdan on your last run you got 10 and 13 wrong, before that 1, 2, 10 and workflow 2, 5 and 6.
Hey @Jon, it would be great, if you could tell me what questions im doing wrong all the time
unique_id:
ebfb5391f6958396bcae3cec6d19c7f1
Hey @Jon could you also tell me what i getting wrong?
unique ID: 848db0008819b7a693ba242c1b3e3ea8
Thanks!
Jon,
Unique ID: 698ec2971a4ad420ade634fb5372322c
Hi @Jon could you check mine please? (3f3e9e9b9720dc7753a2b5c91b3d943b)
Hi @Jon
Can you pls check for me?
Unique ID: bfec52a61bffcab5e6e6643b68858974
I am going to lock this thread for now as the original issue was solved.
