Level 2 certification issues
Hi everyone, I’m currently doing the n8n Level 2 Certification and I’m having an issue with the Discord webhook step.
I created the Error Workflow as instructed and connected the Discord node using the webhook URL that was sent to me by email.
I formatted the message exactly as required in the instructions, replacing the placeholders with the correct expressions from the Error Trigger node and including my unique ID.
However, when I execute the node, I get the response:
“Your message was invalid, Please make sure you are sending the exact text requested.”
Because of this, the quiz says I didn’t alert the team, even though everything seems correctly configured. This issue happens across workflows, not just one.
Has anyone faced this before? Could it be an issue with the webhook itself?
You have an extra space
can you remove the double quote?
I have tried everything possible rearranging the words, removing the spaces, removing qoutes etc. all to no avail.
Still this same response.
I have no issue for mine
Did you copy the message correctly?
I am using the same credentials
The workflow {{ $json.workflow.name }} failed, with the error message: {{ $json.execution.error.message }}. Last node executed: {{ $json.execution.lastNodeExecuted }}. Check this workflow execution here: {{ $json.execution.url }} My Unique ID: ba079798542bce36e9ac7b30ffec6dec
I FACE PROBLEM I THIS
message
Your message is incorrectly formatted.
