Hello everyone,
I’m having an issue with the Level 2 course completion, and it seems to be the same problem reported by other users.
Current situation:
Quiz result: 14/15 (passed)
Workflow 2 and Workflow 3: completed and recognized
Step “Getting data from the warehouse” remains
incomplete -
Badge is not issued
What I’ve already checked and confirmed:
Workflow 1 follows the course instructions (HTTP Request → Airtable → Merge by key → Sort)
Dataset URL and unique_id header are correct
Airtable customers table has region and subregion filled
Merge node is set to Merge by Key (customerID)
Sort node is set to orderPrice, descending
Workflow has been executed successfully and saved
Quiz answers align with the actual workflow output
Verification endpoint still reports the step as incomplete
I consistently get 14/15, and changing quiz answers does not affect the result, which suggests this may be a course validation issue rather than an incorrect workflow or answer.
My Unique ID:
d776f7e558db4c3e496294f2d5793620
Has anyone else experienced this recently?
Is there a known issue with the Level 2 validator for the “Getting data from the warehouse” step, or would this require a manual review?
Thanks in advance for any guidance.
