Level 2 - Split in Batche node
Hey community!
I’m passing the level 2 certificate and I have got a problem with the 11 question because the data are not corresponding.
This is the question:
And the last item in the first batch does not return one of the above choices:
I’ve rechecked all my nodes but haven’t found the issue.
Can anybody help here ?
Many thanks
Hey @fischera,
If you select run at the top and select run 6 it will should show you the last item. Split in batches will take the data and perform as many loops as you tell it to based on the batch size so when you click on the node you will normally see the first run and you would need to select one of the other entries to see more runs.
Thanks @Jon ! Clearer to me.
