Licensing Inquiry: Commercializing a SaaS with Self-Hosted n8n as Backedn Engine
Hello n8n community,
I am building a web platform and would like to clarify the licensing requirements for my specific use case.
Product Overview: I have developed a "resume and job search” web application. The workflow is as follows:
  • Input: Users upload a resume and a job URL via my custom HTML frontend.
  • Processing: A self-hosted n8n instance (running on Docker) processes the resume and job url in the backend to generate a tailored resume, cover letter, and jobs.
  • Output: The user receives the updated resume and a personalized cover letter through their email. While also getting jobs through a job API straight to my custom frontend.
Architecture & User Access
  • Backend: n8n is used strictly as an internal backend engine.
  • No UI Access: End-users interact only with my custom web UI. They have absolutely no access to the n8n canvas, credentials, or node interface.
  • No Syncing: User accounts are managed entirely on my platform - postgres database (email/user account); there is no user account creation or syncing within the n8n instance using external accounts.
My Question: If I monetize this current platform using a freemium model, since the n8n instance is not open to the end-user, can I operate this under the standard self-hosted license (since it powers my backend only), or does this constitute a commercial use case that requires a specialized Embed or Commercial license (due to monetization efforts)?
Thank you for your time and clarification.
I think you’ll need a license for this since it’s a commercial use,
Read this and compare it with your case:
@pedrocks03 Did you get any answer to your question?
Did you need an Embed License or was your case falling under the Sustainable License?
Thanks!
P.S.: I am curious about your SaaS! Did you launch anything? Do you have a link to try it out?
This post explains it in a brief and simpler way:
