I created an AI agent with a fairly long system prompt. It works, but the prompt is sent with every interaction, even if the user types “hello”.
What are the best practices to prevent this?
Outside of context of n8n, I think the best practice for token preservation is prompt caching.
Here is also a guide about it on OpenAI here. Similar guides can be found for other major players. For the cache to stay valid the requests have to be happening pretty often though.
Thanks, but this can be done only with API calls, not with the AI agent node and its tools, right?
Correct, only with API right now (as far as I know).
