LinkedIn Article Post Failing on URL
Unable to post Article to LinkedIn
“Your request is invalid or could not be processed by the service”
The rest of the workflow just uses Gemini to construct a post, then that text blob is passed to this LinkedIn node
Screenshot of the input, node configuration, and error message:
  • n8n version: 1.102.4 (Self Hosted)
  • Operating system: Windows 11 Pro (10.0.22631 N/A Build 22631)
Did you get authorized mail from LinkedIn to make post on LinkedIn through n8n?
Yeah I have the right permissions and access to the Advertising API to allow posting as an Org. Confirmed the credentials connect successfully, it’s just the posting that doesn’t work.
