LinkedIn node does not work anymore. Errore20250401 not supported
Hi, I’m having a problem with my n8n installation for LinkedIn posts. I’ll tell you right away that until yesterday there were no problems.
Today, however, the post isn’t working, and I get this message:
Your request is invalid or could not be processed by the service
Requested version 20250401 is not active
I tried reconnecting my LinkedIn account, but nothing changed.
I’m using Version 1.123.9
Thanks. your n8n setup
  • n8n version: community 1.123.9
  • Database (default: SQLite): sqlite
  • Operating system: Linux Debian
Hi Michel,
This is a classic API deprecation issue. LinkedIn routinely sunsets older versions of their API, and it looks like they just pulled the plug on the 20250401 version today. That is exactly why your workflow ran perfectly yesterday but is throwing this specific error today — LinkedIn flipped the switch on their end.
Since the built-in LinkedIn node has that API version hardcoded into its requests, you have two ways to fix this:
1. Update your n8n instance The n8n team is usually incredibly fast at pushing hotfixes for these LinkedIn version bumps. Check if there is a newer npm release available beyond 1.123.9 and update your instance. A simple update usually contains the newly mapped API version.
2. The HTTP Request workaround (If no patch is out yet) If you can’t wait for a patch, you can bypass the built-in node completely. Just replace it with an HTTP Request node.
  • Set the authentication to use your existing predefined LinkedIn OAuth2 credential.
  • Point it to the LinkedIn posts API endpoint.
  • In the Headers section of the HTTP node, manually add LinkedIn-Version and set it to a currently active version (check LinkedIn’s API docs for the latest stable YYYYMMDD format).
This will get your posts flowing again immediately while waiting for the official node update.
hi @Michel_Morelli
I suggest update n8n to the lastest version stable and recreate the linkedin node.
If you need an immediate workaround , publish via http request using an active linkedin-version header. If reconnecting doesn’t fix it, it means the problem lies with the version header sent by the node itself, not the token.
Last version Version 1.123.31 does not work. I will try with http.
yeah, unfortunately regressions happen in the newer minor versions sometimes. falling back to the raw http request node is definitely the safest play here until they patch the dedicated node. let me know if you need help formatting the headers or payload for the http call!
@Michel_Morelli in your HTTP Request node set a header Linkedin-Version with value 202604 (the latest active one), LinkedIn sunset 202504 on April 7th so any version from 202505 up to 202604 will work. the built-in node hardcodes the old value so updating n8n alone won’t help until they push a patch for it
I’m on v2.16.1 and having the same issue. Hopefully, this is fixed soon.
Hi, I’m having the same error on my n8n installation when trying to publish LinkedIn posts.
It was working normally until yesterday, but today I started getting this message:
I also tried reconnecting my LinkedIn account, but the issue remains.
Could the support team please check and fix this error?
Thanks.
Yes, same thing here.
Even the content is not populating while I use htttp
:fire: Option — Fast + reliable (recommended)
Replace ONLY the LinkedIn node with an HTTP Request node.
You keep your whole workflow, just swap that step.
Example config:
POST to create a post:
POST https://api.linkedin.com/v2/ugcPosts
Headers:
Authorization: Bearer YOUR_ACCESS_TOKEN
LinkedIn-Version: 20240101
Content-Type: application/json
Spot on. I actually default to the raw HTTP Request node for most major APIs anyway. Native nodes are great for quick setups, but the HTTP node gives you absolute control over the exact payload and, more importantly, the error handling.
The only caveat for anyone implementing this exact setup: watch out for token rotation. Since you are handling the ACCESS_TOKEN directly in the header, you’ll want to ensure you have a fallback or an error trigger catching any 401 Unauthorized responses. When that token inevitably expires, you want it to fail loudly so you can refresh it, rather than just silently dropping scheduled posts.
Excellent breakdown of the endpoint and headers!
Hi guys,
Linkedin native node not working · Issue #28559 · n8n-io/n8n
I was able to get this to work using the HTTP node, but it wasn’t as straightforward (esp. if you’re posting images)
I am attaching a sample workflow that uses these HTTP nodes
Step by Step Video Instruction (Loom): LinkedIn Posting on n8n using HTTP Node | Loom
