LinkedIn Nodes or Solution to Send Connection Requests, Check for Replies and Send Messages to connections?
Hey Everyone
Just wondering if there is a solution or number of solutions that anyone has identified in regards to interacting with LinkedIn?
I have already set the API up for use with posting to my LinkedIn Profile but I now want to expand that into automating some of the regular linkedin tasks i do.
So i want to be able to automate sending LinkedIn Connection requests based on leads I have in pipedrive and being able to check back if they have accepted my connection request.
And then from there I want to create a messaging sequence where so I want to be able to check LinkedIn for any replies from leads while also being able to send messages to connections.
I have previously had other solutions to do this but I wanted to group it all in n8n to avoid all the additional subscriptions.
Hey @PattrnData
At the moment the only option would be to use the http request node and follow the LinkedIn API docs to manually build out the requests you want to make.
thanks ye annoyingly thats only available in the compliance API programme which they have 0 documentation on how to apply for that
