Listen for event and fetch event gets stuck for webhook and clickup integration
We are running n8n version 1.55.3 where listen/fetch for event gets stuck enev though we have received success in the execution.
There is no error in the API call response and the UI gets stuck.
response {“data”:“false”}
  • n8n version: 1.55.3
  • Running n8n via (Docker, npm, n8n cloud, desktop app): helm on k8s
  • Operating system: linux
Hi @Ravi_Kumar1,
What do you mean when you say it gets stuck? Could you share a screenshot?
Do you see the event in your logs correctly?
stop listening button is not stoping the workflow
If you can, please update to our latest version - this always weeds out a few possibilities
Do you see the event logged correctly in your logs? And which reverse proxy are you using?
Does this happen in all browsers and in anonymous mode also?
