Live Chat AI Agent Problem when using Live Chat URL
I have a problem with AI agent node, all the process takes like 2-3 minutes to finished and the live chat node get stuck with 3 dots. When I inspect element it shows this error
‘SyntaxError: Unexpected token ‘<’, "<!DOCTYPE "… is not valid JSON
Fl @ chat.bundle.es.js:817’
However when I am testing it via chat inside the workflow, it does not have that issue and works fine or as expected. The AI agent respond back even though it takes a while to complete executing the process and I get acknowledgement that the process has been completed.
The problem only happens when using the live CHAT URL.
When I paste the same script or text in live, it get stuck, inside workflow it works.
  • **n8n version 1.9.3
  • **Database (default: SQLite): n/a
  • **n8n EXECUTIONS_PROCESS setting (default: own, main) main
  • **Running n8n via (Docker, npm, n8n cloud, desktop app): Hosted N8N Cloud
  • **Operating system: Windows 11
Additional Info:
I also tried embed option but it also returns a JSON error. I think the issue could be with the CDN
since the chat do definitely work inside workflow but not either using live chat url or embed mode
