Llm fails and gives error "error": "Cannot read properties of undefined (reading 'message')"
i m using n8n on localhost via nodejs, i m trying to generate the times zone for the places based on the input & then geenrate a single csv file having these timezones in each row and using basicllm & free model in the chatbot for it, but it gives me “error”: “Cannot read properties of undefined (reading ‘message’)” and fails the llm m not getting the desired output from it ,
  "name": "find timezone",
  "nodes": [
      "parameters": {
        "batchSize": 5,
        "options": {
          "reset": false
      "id": "9d581765-cfbb-4815-ac0b-4a1007e10672",
      "name": "Split In Batches",
      "type": "n8n-nodes-base.splitInBatches",
      "typeVersion": 1,
      "position": [
        -180,
        295
      "alwaysOutputData": false
      "parameters": {},
      "type": "n8n-nodes-base.manualTrigger",
      "typeVersion": 1,
      "position": [
        -840,
        295
      "id": "fad341bf-c0f4-46a6-ab14-ff00a93a6d64",
      "name": "When clicking ‘Test workflow’"
      "parameters": {
        "options": {
          "delimiter": ","
      "type": "n8n-nodes-base.extractFromFile",
      "typeVersion": 1,
      "position": [
        -400,
        295
      "id": "a678ec6d-8bd6-4410-b05f-b08fe30566b8",
      "name": "Extract from File"
      "parameters": {
        "fileSelector": "P:/places.csv",
        "options": {
          "dataPropertyName": "data"
      "type": "n8n-nodes-base.readWriteFile",
      "typeVersion": 1,
      "position": [
        -620,
        295
      "id": "a0f6f571-4d8b-434a-86e0-2c897cc67bf7",
      "name": "Read/Write Files from Disk"
      "parameters": {
        "operation": "toFile",
        "fileFormat": "csv",
        "binaryPropertyName": "={{ $json.output.Timezone }}",
        "options": {
          "fileName": "P:/timezone.csv"
      "name": "Spreadsheet File1",
      "type": "n8n-nodes-base.spreadsheetFile",
      "typeVersion": 1,
      "position": [
        1100,
        100
      "id": "b7808fec-dacd-4da7-aaea-8ed29f9aa439"
      "parameters": {
        "options": {}
      "typeVersion": 3,
      "position": [
        60,
        20
      "id": "7f198072-90f4-4592-8a40-bdc0e9802465",
      "name": "Loop Over Items"
      "parameters": {
        "promptType": "define",
        "text": "=state: {{ $json.state }}",
        "hasOutputParser": true,
        "messages": {
          "messageValues": [
              "message": "=You are an intelligent assistant well versed with geography. Based on the state given to you by user or human in prompt, find the GMT time zone applicable to it.\n\n#Input\nstate: {{ $json.state || \"Unknown Location\" }}\n\n#Output\n{\n  \"Timezone\": \"\"\n}\n\nYour response must strictly follow the JSON format above with the Timezone field properly filled in. The Timezone should be expressed as a string with the GMT offset (e.g., \"+5.5\", \"-4\", \"+0\").\n\nExample 1:\n#Input\n\"Pune\"\n\n#Output\n{\n  \"Timezone\": \"+5.5\"\n}\n\nExample 2:\n#Input\n\"Maharashtra\"\n\n#Output\n{\n  \"Timezone\": \"+5.5\"\n}\n\nExample 3:\n#Input\n\"India\"\n\n#Output\n{\n  \"Timezone\": \"+5.5\"\n}\n\nAlways return valid JSON format that can be parsed by n8n. Do not include any explanatory text outside of the JSON structure.\n\n"
      "type": "@n8n/n8n-nodes-langchain.chainLlm",
      "typeVersion": 1.6,
      "position": [
        480,
        20
      "id": "5ae7cb93-2811-461b-92e7-8e160807db75",
      "name": "Basic LLM Chain",
      "retryOnFail": true,
      "onError": "continueRegularOutput"
      "parameters": {
        "jsonSchemaExample": "{  \n  \"Timezone\": \"\"\n}"
      "type": "@n8n/n8n-nodes-langchain.outputParserStructured",
      "typeVersion": 1.2,
      "position": [
        680,
        240
      "id": "d01a9361-5793-482a-aaad-511f78eab8e7",
      "name": "Structured Output Parser"
      "parameters": {
        "model": "nvidia/llama-3.3-nemotron-super-49b-v1:free",
        "options": {}
      "type": "@n8n/n8n-nodes-langchain.lmChatOpenRouter",
      "typeVersion": 1,
      "position": [
        480,
        300
      "id": "555f6e2d-fdab-4e8f-8021-08658700dd29",
      "name": "OpenRouter Chat Model",
      "credentials": {
        "openRouterApi": {
          "id": "YCRLuvBrVkvzzjz4",
          "name": "openrouter chat bot"
      "parameters": {
        "jsCode": "// Get the raw input string from the 'places' node\nconst input = $json.place || \"\";\n\n// Split by comma\nconst parts = input.split(', ').map(p => p.trim());\n\n// Extract city and state\nconst city = parts[0] || \"\";\nconst state = parts[1] || \"\";\n\n// Return formatted JSON\nreturn [\n  {\n    json: {\n      city,\n      state\n    }\n  }\n];\n"
      "type": "n8n-nodes-base.code",
      "typeVersion": 2,
      "position": [
        120,
        300
      "id": "3689318c-3c6e-4525-b0d7-f6426577802c",
      "name": "Code1"
      "parameters": {
        "mode": "combine",
        "combineBy": "combineByPosition",
        "options": {}
      "type": "n8n-nodes-base.merge",
      "typeVersion": 3.1,
      "position": [
        880,
        120
      "id": "9e62f0b0-bf3a-4fcb-9e35-58c2e9b03942",
      "name": "Merge"
      "parameters": {
        "amount": 1
      "type": "n8n-nodes-base.wait",
      "typeVersion": 1.1,
      "position": [
        856,
        345
      "id": "68e49ccc-e3b1-4f31-919a-bf17d3f1dc23",
      "name": "Wait",
      "webhookId": "0558c280-85d4-4720-a198-f5934422989b"
  "pinData": {},
  "connections": {
    "Split In Batches": {
      "main": [
            "node": "Loop Over Items",
            "type": "main",
            "index": 0
    "When clicking ‘Test workflow’": {
      "main": [
            "node": "Read/Write Files from Disk",
            "type": "main",
            "index": 0
    "Read/Write Files from Disk": {
      "main": [
            "node": "Extract from File",
            "type": "main",
            "index": 0
    "Extract from File": {
      "main": [
            "node": "Split In Batches",
            "type": "main",
            "index": 0
    "Spreadsheet File1": {
      "main": [
    "Loop Over Items": {
      "main": [
            "node": "Code1",
            "type": "main",
            "index": 0
            "node": "Merge",
            "type": "main",
            "index": 1
    "Structured Output Parser": {
      "ai_outputParser": [
            "node": "Basic LLM Chain",
            "type": "ai_outputParser",
            "index": 0
    "OpenRouter Chat Model": {
      "ai_languageModel": [
            "type": "ai_languageModel",
            "index": 0
    "Basic LLM Chain": {
      "main": [
            "node": "Merge",
            "type": "main",
            "index": 0
            "node": "Wait",
            "type": "main",
            "index": 0
    "Code1": {
      "main": [
            "type": "main",
            "index": 0
    "Merge": {
      "main": [
            "node": "Spreadsheet File1",
            "type": "main",
            "index": 0
    "Wait": {
      "main": [
            "type": "main",
            "index": 0
  "active": false,
  "settings": {
    "executionOrder": "v1"
  "versionId": "0a58e663-08ff-4060-9d75-62c8e09afb8a",
  "meta": {
    "instanceId": "7e17052359c1df516e7f3a27dabc5631cbc7be8e742a6f1a2871050b378afa67"
  "id": "5HkRVIR4XH4IGgmQ",
  "tags": []
So that is a js error that indicates that the message object was empty, presumably the LLM replied with nothing or an error so it caused a downstream issue when accessing the response later.
Hi @Renuka
Open a separate workflow and test this suggestion below.
I hope it helps you
  "nodes": [
      "parameters": {
        "batchSize": 5,
        "options": {
          "reset": false
      "typeVersion": 1,
      "position": [
        -180,
        295
      "parameters": {},
      "typeVersion": 1,
      "position": [
        -840,
        295
      "parameters": {
        "options": {
          "delimiter": ","
      "typeVersion": 1,
      "position": [
        -400,
        295
      "parameters": {
        "options": {
      "typeVersion": 1,
      "position": [
        -620,
        295
      "parameters": {
        "operation": "appendTo",
        "fieldsToInclude": {
          "fieldValues": [
              "field": "city"
              "field": "state"
              "field": "Timezone"
        "values": {
          "valueValues": [
              "value": "={{ $items[0].json.city }}"
              "value": "={{ $items[0].json.state }}"
              "value": "={{ $items[1].json.Timezone }}"
        "options": {
          "fileName": "P:/timezone.csv",
          "alwaysQuote": true
      "typeVersion": 1,
      "position": [
        1100,
        100
      "parameters": {
        "options": {}
      "typeVersion": 3,
      "position": [
        60,
        20
      "parameters": {
        "messages": {
          "messageValues": [
              "message": "=You are an intelligent assistant well versed with geography. Based on the state given to you by user or human in prompt, find the GMT time zone applicable to it.\n\n#Input\nstate: {{ $json.state || "Unknown Location" }}\n\n#Output\n{\n  "Timezone": ""\n}\n\nYour response must strictly follow the JSON format above with the Timezone field properly filled in. The Timezone should be expressed as a string with the GMT offset (e.g., "+5.5", "-4", "+0").\n\nExample 1:\n#Input\n"Pune"\n\n#Output\n{\n  "Timezone": "+5.5"\n}\n\nExample 2:\n#Input\n"Maharashtra"\n\n#Output\n{\n  "Timezone": "+5.5"\n}\n\nExample 3:\n#Input\n"India"\n\n#Output\n{\n  "Timezone": "+5.5"\n}\n\nAlways return valid JSON format that can be parsed by n8n. Do not include any explanatory text outside of the JSON structure.\n\n"
      "typeVersion": 1.6,
      "position": [
        480,
        20
      "parameters": {
        "options": {}
      "typeVersion": 1,
      "position": [
        480,
        300
      "credentials": {
        "openRouterApi": {
      "parameters": {
        "jsCode": "// Get the raw input string from the 'places' node\nconst input = $json.place || "";\n\n// Split by comma\nconst parts = input.split(', ').map(p => p.trim());\n\n// Extract city and state\nconst city = parts[0] || "";\nconst state = parts[1] || "";\n\n// Return formatted JSON\nreturn [\n  {\n    json: {\n      city,\n      state\n    }\n  }\n];\n"
      "typeVersion": 2,
      "position": [
        120,
        300
      "name": "Code1"
      "parameters": {
        "mode": "combine",
        "options": {}
      "typeVersion": 3.1,
      "position": [
        880,
        120
      "name": "Merge"
      "parameters": {
        "amount": 1
      "typeVersion": 1.1,
      "position": [
        856,
        345
      "name": "Wait",
  "pinData": {},
  "connections": {
      "main": [
            "type": "main",
            "index": 0
      "main": [
            "type": "main",
            "index": 0
      "main": [
            "type": "main",
            "index": 0
      "main": [
            "type": "main",
            "index": 0
      "main": []
      "main": [
            "node": "Code1",
            "type": "main",
            "index": 0
            "node": "Merge",
            "type": "main",
            "index": 1 // Input 1 for Merge (Original Item)
            "index": 0
      "main": [
            "node": "Merge",
            "type": "main",
            "index": 0 // Input 0 for Merge (LLM Result)
            "node": "Wait",
            "type": "main",
            "index": 0
    "Code1": {
      "main": [
            "type": "main",
            "index": 0
    "Merge": {
      "main": [
            "type": "main",
            "index": 0
    "Wait": {
      "main": [
            "type": "main",
            "index": 0
  "active": false,
  "settings": {
  "versionId": "0a58e663-08ff-4060-9d75-62c8e09afb8a", // You might want to update this or let n8n assign a new one
  "meta": {
    "instanceId": "7e17052359c1df516e7f3a27dabc5631cbc7be8e742a6f1a2871050b378afa67" // This will likely change in your instance
  "id": "5HkRVIR4XH4IGgmQ", // This will likely change in your instance
  "tags": []
If this suggestion solved your problem, please mark my post as a solution (blue box with check mark) so that this ongoing discussion does not distract others who want to find the answer to the original question and click the heart. Thanks
hi @interss i still get the error
