Locally host N8N with docker and cloudflare tunnel but facing this issue while using telegram Trigger
Are you sure the acces token is correct?
Is you instance public?
My connections seems ok.
the access token is correct
but where can i found out about the instance?
In your yml file among the others env variables.
i didn’t find anything releated like that.
but still I’m searching how can i fix this issue.
Check your bot with BotFather, ans see its status.
It seems offline? it cannot be reached?
