LocalTunnel with Self-hosted-ai-starter-kit
Hello there!
Has anyone managed to receive incoming messages from Telegram using LocalTunnel with Self-hosted-ai-starter-kit? (no cloud).
As far as I understand, Telegram requires HTTPS and am exposign it on localhost:5678
Hey, thank you for your response.
This was also set on my browser
https://api.telegram.org/MY-BotFather-ipi-key/setWebhook?url=https://shaky-crabs-drum.loca.lt/webhook-test/Telegram
Givining as result:
{“ok”:true,“result”:true,“description”:“Webhook was set”}
I even tried with a webhook instead of the Telegram node, but it keeps listening forever.
  • n8n version:**1.76.3
  • No Database in the workflow even though Postgres is included in the Kit
  • I haven’t explicitly set the EXECUTIONS_PROCESS setting, so it’s likely using the default (own). Would this affect my ability to receive incoming messages from Telegram via LocalTunnel?
  • Docker (localhost:5678)
  • Ubuntu 24.04
I hope my response is not too messy
