Looking for 1 n8n workflow case with an explicit expected label or routing policy
I’ve now tested 3 materially different workflow lines locally in a narrow Phase 1 setup.
What I have so far:
  • voucher validation
  • invoice extraction / strict schema validation
  • support email classification / routing
That helped confirm boundary behavior, but the current evidence is still mostly boundary-oriented.
The next thing I’m looking for is not just “another workflow”.
I’m looking for 1 real n8n case where at least one of these is already explicit:
  • an expected label
  • a routing policy contract
  • a business rule that clearly defines when the workflow should continue vs stop
Best fit examples:
  • classification where the expected class is known
  • routing / triage with a defined policy
  • compliance / policy checks
  • document-to-system handoff with a strict downstream rule
Why this is the next step:
I already have boundary-oriented cases.
Now I want one case that lets me test something closer to semantic correctness or stronger policy correctness, not just whether malformed output stops safely.
A short outline is enough first.
I do not need full payloads immediately.
What helps:
  • rough payload shape
  • target schema
  • expected label or explicit policy rule
  • short note on downstream risk
  • polling or webhook preference
What I can return:
  • whether the run ended in succeeded or failed_safe
  • a short reason if relevant
  • a receipt reference
This is still narrow Phase 1 work, not broad onboarding.
Public kit:
If you have a case like this, reply here or DM me.
Solid approach — testing with explicit label/routing is exactly how to isolate semantic correctness from boundary safety. I’d go classification-first: define your expected classes upfront (voucher type, invoice category, email severity tier), then validate downstream that the label matches your schema. That gives you a hard pass/fail boundary test. The routing policy after that becomes the downstream risk measure — ‘what breaks if the label is wrong?’ For phase 1, I’d suggest starting with one complete case where the label is explicit, then layer in the partial/ambiguous cases. That sequence surfaces which part of your system needs hardening.
That makes sense — I agree.
What I have so far is still mostly boundary-oriented:
  • malformed output
  • enum violations
  • provisional threshold-policy behavior
So yes, the next useful step is exactly what you described:
start with one case where the expected label is explicit, then separate:
  1. did the output pass the boundary safely?
  2. was the label actually the right one?
  3. what downstream action becomes wrong if the label is wrong?
That would let me test something closer to semantic correctness instead of only boundary behavior.
If you have a concrete n8n case where the expected class is already known upfront, that would be a very strong fit for what I’m looking for next.
Invoice classification is the perfect starting point. Define your expected categories upfront (e.g., ‘PurchaseOrder’, ‘CreditMemo’, ‘Invoice’) as your label set. Run the extraction, then validate: did the model pick one of your known classes? If yes, pass to routing. If no or ambiguous, fail_safe. That gives you a clear semantic boundary test — the label either matches your schema or it doesn’t. You’ll quickly see where the model struggles (e.g., mixed P.O.s) and what business rule catches it. Start there, iterate.
That’s helpful — and I think this is the right direction.
The important distinction on my side is:
  • boundary safety = did the output stay within the allowed class set?
  • semantic correctness = did it match the expected label for this specific case?
  • business policy = what should happen when the case is ambiguous or borderline?
So yes, invoice classification could be a strong next step if the expected label is explicit upfront, because that would let me test more than schema validity alone.
If you’re open to it, what would help most is:
  • one simple example with an explicit expected label
  • optionally one “mixed / ambiguous” example where the business rule matters
That would be a very good fit for the next phase on my side.
Exactly — that’s the right progression for Phase 1. Start with one concrete case where the label is known (Invoice, PurchaseOrder, CreditMemo types are ideal), test the classification boundary, then measure downstream impact when the label is wrong. You’ll quickly see what needs hardening. Start narrow, scale from there.
That makes sense — agreed.
So I’ll treat that as the next likely direction on my side:
start with one invoice-document classification case where the expected label is explicit, then keep the mixed / ambiguous case as the next layer.
That should let me test:
  • allowed class-set boundary
  • expected-label correctness
  • downstream impact when the label is wrong
If you’re open to it, the next useful step would be:
  • optionally one mixed / ambiguous example
  • the business rule for how the ambiguous one should be handled
That would be a very strong fit for the next phase on my side.
