Looking to hire n8n developers for ongoing automation projects - what should I look for?
We’ve been scaling up our internal automation stack pretty heavily over the past few months mostly around CRM syncs, lead routing, and some light AI agent workflows. We’ve hit a point where the complexity is beyond what our team can handle part-time.
I’ve started exploring options to hire n8n developers, either freelance or on a contract basis, but I’m honestly not sure what the right bar is when vetting candidates. Most people can say they “know n8n” but that can mean anything from dragging a few nodes around to building robust sub-workflow architectures with proper error handling.
A few things I’m curious about from folks here who’ve either hired or been hired for n8n work:
  1. What would you consider a strong signal of n8n proficiency?
Portfolio workflows? Contributions to the community? Custom node development?
  1. How do you scope projects?
We have some well-defined needs but also some that are more exploratory, wondering if a discovery/audit phase is standard practice.
  1. Freelance platforms vs. direct hire?
We tried Upwork briefly but it felt like a lottery. Has anyone had better luck posting directly here in the Jobs category or through referrals?
Hey :waving_hand:,
I’m Milan, with 8 years of experience in Business Automation and AI. Including 2 years at Apify working on enterprise-level browser automation.
Currently specializing in n8n, but also proficient in Python & Javascript.
Find out more about my work here:
If you think I might be a match, please:
Book a call here with me
Or reach out at hello@smoothwork.ai
Looking forward to hearing from you!
Hi Emma,
Your post resonated with me because the challenge you’re describing , a stack that’s grown faster than the team’s bandwidth to manage it is exactly where I do my best work.
I’m Basit, founder of basitq.cloud. I specialize in building production-grade n8n automation architectures: not just connecting nodes, but designing systems that are maintainable, observable, and built to survive real-world load.
Here’s what I’d bring to your engagement specifically:
CRM syncs & lead routing : I’ve built multi-system CRM pipelines with conditional routing, deduplication logic, and fallback handling. I don’t build linear chains; I build branching workflows with error paths baked in from day one.
AI agent workflows: I have hands-on experience wiring LLM-based agents into n8n, including memory patterns, prompt chaining, and graceful failure handling when model responses go off-script.
Sub-workflow architecture : For stacks at your complexity level, I design modular workflow systems where logic is reusable and updates don’t cascade into breakage.
I’d recommend we start with an exploration call of 45 minutes where I audit your existing workflows, map dependencies, surface brittle points, and deliver a clear architecture proposal. You own that document regardless of what happens next. It de-risks the engagement for you and ensures any build work is scoped accurately, not guessed at.
This is standard practice for stacks beyond a certain complexity, and yours sounds like it qualifies.
If that sounds like the right starting point, I’m happy to jump on a 30-minute call to understand the stack before proposing a specific scope and rate.
Looking forward to it.
Basit
Portfolio
There is a load of fake experts around.
Very often hard to figure out who the real experts are that will help yoi properly. With that it is probably mostly about gut feeling when you talk to them on an online call or whatever.
Best bet would be to message some from experts.n8n.io
Emma, for CRM syncs + lead routing + light agent workflows, I would vet around one real workflow rather than a broad portfolio call.
Ask for a tiny production test:
  • input/output contract and the IDs used for dedupe
  • what happens on API timeout, partial CRM write, duplicate lead, or bad payload
  • where failed leads get logged or sent for manual review
  • a short before/after test matrix your team can reuse
That separates someone who can wire nodes from someone who can leave you with maintainable automation. The first paid slice should be one workflow cleaned up, documented, and proven against those edge cases; after that you know if they can own the bigger stack.
oimrqs ops - my email is in my profile if you want me to map that first paid pilot against a redacted current flow.
One thing worth clarifying before you start interviewing:
The real split isn’t “knows n8n vs doesn’t” — it’s “workflow builder” vs “automation system owner.”
A workflow builder can connect nodes and handle API errors. A system owner will define the data model, flag dependencies between workflows, and make clear where failures should alert your team.
For what you described — scaling up heavily, CRM syncs, lead routing, and AI agent workflows — you probably need the second.
A simple filter I’d use: don’t only test whether the workflow runs. Test whether they hand back something your team can maintain without them.
For example:
  • what can safely be edited by your team later
  • which fields are the source of truth
  • where failed leads go
  • what depends on what
  • when a human should be alerted
A workflow plus a one-page maintenance note on fragile points, dependencies, and failure paths is a much stronger signal than a clean demo.
The test approach @oimrqs_ops described above is a solid starting point for surfacing this.
Hey Emma
This is one of the more honest posts I’ve seen in this category — most people either underscope the problem or assume any n8n experience is transferable. It’s not. Let me break this down properly.
1. What actually separates a real n8n developer from someone who “knows n8n”
The gap isn’t about node count or workflow complexity — it’s about how someone thinks when things break in production.
Here’s the interview question I’d use before anything else:
“You have a CRM sync workflow that runs every 15 minutes. The CRM API starts returning 429s intermittently. Walk me through how you’d handle it — end to end.”
A surface-level candidate will say: “I’d add a Wait node and retry.” That’s not wrong, but it’s incomplete.
A production-ready developer will talk about:
  • Exponential backoff with jitter, not fixed waits
  • Idempotency — making sure a retry doesn’t double-write records
  • Dead-letter logic — where does the failed execution go, who gets alerted, how does it get replayed?
  • Execution monitoring — are you watching queue depth, not just individual runs?
  • Whether this workflow should be broken into a trigger + sub-workflow so failures are isolated
That answer tells you everything. If they can’t walk through it fluently, they’ve never owned a workflow in production — they’ve only built demos.
Other strong signals to look for:
  • They talk about credential management across environments (dev/staging/prod separation)
  • They’ve used n8n’s execution data for debugging, not just the canvas
  • They know when NOT to use n8n (some things belong in code, not a workflow)
  • They’ve built or contributed custom nodes — not required, but it means they understand the internals
  • They think in systems: how workflows talk to each other, how to avoid circular dependencies, how to version logic safely
Portfolio workflows are nice but easy to fake. A 30-minute technical call on a real problem they’ve solved will tell you more than 10 screenshots.
2. How to scope this properly — especially the exploratory parts
For a stack at your stage — CRM syncs, lead routing, AI agent workflows already in production — jumping straight into a build contract is a mistake. Not because the work isn’t defined, but because no one outside your team actually understands the dependencies yet.
A discovery/audit phase is standard practice for any serious contractor, and it should be scoped as a paid, fixed deliverable — typically 5–15 hours depending on your stack size. Here’s what that phase should produce:
Workflow dependency map — which workflows trigger which, what breaks if X goes down, where your single points of failure are right now
Failure risk classification — every active workflow rated by: what’s the business impact if it fails silently? (Silent failures in CRM syncs are brutal — you don’t know until your sales team notices dirty data weeks later)
Architecture recommendations — where to consolidate, where to modularize, which AI agent patterns are sustainable vs. fragile
Prioritized build backlog — separating your well-defined needs from the exploratory ones, with rough effort estimates
This document becomes your single source of truth for the engagement. Any contractor who skips this and jumps straight to quoting hours either doesn’t understand your stack or doesn’t want to — both are red flags.
For the exploratory work specifically: scope it in short cycles (1–2 week sprints with a defined deliverable each time), not a single open-ended contract. This protects you when requirements shift, which they always do with AI agent work.
3. Where to actually find good people
Upwork’s problem isn’t the talent pool — it’s the incentive structure. The algorithm rewards fast responses and low bids. The developers who are good enough to not need Upwork usually aren’t on it, and the ones who are on it have learned to optimize for winning proposals, not delivering quality. You experienced this.
What actually works, in order of reliability:
This community (n8n forum + Discord) — People who are active here have genuine stakes in the ecosystem. A referral from someone in this thread carries more signal than 50 Upwork reviews. The Jobs category here has a much better hit rate because the audience self-selects.
Direct referrals from adjacent networks — Who built the automation stack at a company similar to yours? Ask in SaaS operator communities (Lenny’s, SaaStr Slack, RevOps communities). Someone who’s solved your exact CRM + lead routing problem before is worth 3x a generalist.
LinkedIn — but with a specific filter — Don’t search “n8n developer.” Search for people who post about automation architecture, RevOps infrastructure, or AI agent workflows. People who write about the problems (not just the tool) are thinking at the right level.
Paid technical assessment — Regardless of source, offer a small paid test project (~3–5 hours, $200–500) before committing to a full engagement. Give them a real scenario from your stack — a simplified version of your CRM sync with a realistic edge case baked in. How they scope it, what questions they ask, and what they deliver tells you more than any interview.
One last thing worth naming: the combination you’re describing — CRM syncs + lead routing + AI agent workflows — is genuinely complex infrastructure. It’s not a “hire a freelancer for a one-off” situation. What you actually need is someone who can function as a part-time automation architect: someone who owns the system, not just executes tickets.
That framing changes who you’re looking for and what you’re willing to pay for them.
Happy to go deeper on any of this — particularly the AI agent architecture side, which has its own set of failure patterns worth understanding before you build further.
Hamza
itsameerhamza203@gmail.com
Came across your post about scaling your n8n automation stack. CRM syncs with lead routing and AI agents is exactly what we build.
We helped our client in saving $80k/month.
Happy to walk through a real-world example and propose a scoped pilot to de-risk the engagement. You can reach me at farhan@experlabs.com
Hi Emma,
A useful signal is whether the person thinks beyond connecting nodes. For CRM syncs, lead routing and AI workflows I would look for:
- clear data model and source-of-truth decisions
- idempotency/deduplication so records are not created twice
- error branches, retries and alerts
- logs that a non-developer can understand
- test cases with real examples
- documentation and handover notes
For stacks that are already getting complex, I would start with a small discovery/audit: map the current workflows, identify brittle points, define the first fixed-scope build, then implement one workflow as a paid test.
This is the kind of work I am focused on: AI-assisted automation systems for small businesses, with n8n/APIs, CRM-style logic, WhatsApp/customer follow-up and clear handover documentation.
Current work:
I am based in Spain and available for remote async collaboration. Contact: jorgelg1177@gmail.com
Hi Emma,
Three signals I’d test for before hiring an n8n developer for production workflows, sharpest first:
  1. Ask for ONE n8n + Postgres (or n8n + SQLite) deployment they have personally operated in production for 90+ days. Not built and shipped — operated. The follow-up that reveals who has actually done this: “How do you handle the case where step 3 returns 200 but the downstream system silently lost the write?” If they say “retry the workflow,” they’ve never run a real workflow under real load.
  2. Ask them to show their error-handling pattern, not describe it. “Send me the JSON of one production workflow you’ve bug-fixed at least 3 times.” You’re looking for: dedicated error workflows, retry with exponential backoff, dead-letter queues for unrecoverables, and alerting that’s quiet on expected transients but loud on regressions.
  3. Test their boundary thinking. Scope a workflow you describe as “easy” but with a hidden hard part — like deduplication across two sources with fuzzy matching. The candidates who say “easy, 2 hours” fail. The good ones ask about the de-dupe key, edit-distance threshold, conflict resolution, and audit log before quoting.
For sourcing: at the senior end, Upwork is a lottery. Discourse threads here, GitHub contributors to n8n community nodes, and warm intros tend to convert better and stay longer.
For your specific stack (CRM syncs + lead routing + light AI agent workflows), happy to share the vetting questions I’d use against that exact use case on a 30-min call. DM me if useful.
— Priyanshu Kumar
AI & Automation Engineer
Hi Emma,
For the kind of stack you described, I would treat “knows n8n” as a low bar and look for evidence of production habits.
Strong signals I would check:
  • They can explain how they split large workflows into reusable sub-workflows.
  • They show error paths, retries where safe, and notification/logging behavior, not only the happy path.
  • They can describe how they prevent duplicate CRM writes and lead-routing loops.
  • They document environment variables, credentials, ownership, and handoff steps clearly.
  • They are comfortable saying when a proper database or queue is better than forcing everything through Sheets or one huge workflow.
For scoping, I would usually start with a small paid audit/discovery pass for an existing stack: map the current workflows, identify brittle points, rank fixes, and propose a first build slice. For CRM syncs and lead routing, that first slice is often a single end-to-end path with deduping, logging, and failure alerts. If that works cleanly, expand into the rest.
I build in this lane: n8n workflows, API/CRM integrations, Google Sheets/Slack/Gmail, AI classification, and reliability/handoff docs. If useful, I can share a concrete checklist or help review one workflow/spec so you know what a production-ready proposal should include.
Hi Emma, for the stack you described I would look for production habits, not just n8n familiarity.
A paid discovery/audit phase is normal here. For CRM syncs, lead routing, and light AI agent workflows, I would start by mapping existing workflows, failure points, dedupe keys, ownership of credentials/env vars, and one golden path that can be tested end to end.
Strong signals I would ask for:
- how they prevent duplicate CRM writes and routing loops;
- what error workflow, logging, and alerting pattern they use;
- whether they can split monolithic flows into reusable sub-workflows;
- whether they document handoff so a non-dev stakeholder can maintain it;
- whether they ask about data volume, retry policy, and rollback before quoting.
I work in this lane: n8n/Make, CRM/API integrations, Google Sheets/Slack/Gmail, AI classification, QA notes, and handoff docs. A small first result I would suggest is a 1-2 hour paid workflow audit with a prioritized fix list and one scoped build slice.
One question: are your highest-risk workflows CRM syncs, lead routing, or AI-agent decisions?
Great thread — most of the answers cover what to test for. Adding a builder’s-side view on the parts the thread hasn’t really touched: pricing structure, scope of a “paid audit,” and what ongoing maintenance actually costs.
Signals beyond the obvious ones already mentioned
  1. They write down the failure mode before they write the workflow. Ask any candidate: “What happens if the third API call returns 500 after the first two succeeded?” A workflow builder gives you a generic answer about retries. A system owner walks you through the idempotency marker, the compensating action, the audit row that gets written, and where the operator notification lands.
  2. They ask about your audit/compliance posture in the first conversation. Anyone who jumps to “let’s wire up nodes” without asking who needs to read the logs in 18 months is not someone you want owning multi-year infrastructure.
  3. They have an opinion on n8n vs code. Strong candidates can tell you when to drop out of n8n into a Code node, a sub-workflow, or an external script — and why. “Everything in n8n” is as much a red flag as “n8n can’t do that.”
  4. They estimate maintenance as a percentage of build cost, not zero. Real number: 15–25% of the initial build cost per year for any workflow touching live external APIs. If a candidate quotes a build but waves off maintenance, they’re going to ghost you in month 4.
  5. They use version control for workflow JSON. If their answer to “how do you roll back a broken deploy?” is “I’ll fix it in the editor,” skip them.
What a paid audit should actually look like
Scope: 4–8 hours of work, $300–$800 depending on stack complexity. Deliverables: a written dependency map, a list of every silent-failure surface, a recommended environment-separation plan (dev/staging/prod credentials, sub-workflow boundaries), and a prioritized backlog. If someone offers a “free audit” for an ongoing relationship, the audit will be sales theater, not engineering.
Maintenance retainer math
For an established stack with 8–15 active workflows, a realistic retainer is $400–$1,200/month covering: weekly health-check review, breakage triage within 24 business hours, monthly dependency updates, and quarterly architecture review. If the retainer is structured per-incident rather than monthly, you’ll get incentivized to under-fix.
Sourcing
Agree with the thread that community + referral beats Upwork for ongoing work. One angle nobody’s mentioned: ask candidates to show you one workflow they’re proud of and one they’d rebuild today, and why. You’ll learn more in 10 minutes from that question than from a portfolio review.
Happy to talk through any of this if it’s useful. Building n8n production stacks the same way I built trading-system infrastructure — same disciplines, different domain.
Hi,
Good question. For ongoing automation work, I’d suggest testing freelancers with one small real workflow instead of only looking at portfolios.
A good test task should show:
  • how they structure the workflow
  • how they handle failed executions
  • whether they add logs/retries
  • how clearly they document the handoff
  • whether they can explain tradeoffs simply
I help with n8n-style workflows, APIs, OpenAI/Claude, Google Sheets/CRM syncs, Telegram/Discord bots and automation cleanup.
If you need someone implementation-focused for a small test workflow, I’d be open to helping.
Hello! I really liked your answer and the way you explained the AI automation structure.
My company is based in Brazil, and today we already have a very large volume of inbound leads coming daily through the official Meta WhatsApp API — currently more than 180 new conversations per day.
We sell electric scooters, gasoline motorcycles, parts and services, and I am looking for a robust AI sales structure, not a simple chatbot.
What I need is an AI capable of:
  • handling sales conversations naturally;
  • breaking customer objections;
  • explaining products and differences between models;
  • sending product photos and demonstration videos automatically;
  • talking about financing, delivery and pricing;
  • qualifying leads;
  • transferring hot leads to human salespeople when necessary;
  • operating 24/7 without interruptions.
The idea is to integrate everything with:
  • Official Meta WhatsApp API;
  • Kommo CRM;
  • OpenAI;
  • N8N automations;
  • and a learning/knowledge base structure for continuous improvement.
I would like to understand if this is a service you provide and whether you already have experience with projects like this.
If possible, I would also like to see real case studies or examples already running.
My Number wathsapp 55+16-99774-4171
Thank you!
Hi Emma,
For CRM syncs, lead routing, and light AI-agent workflows, I would vet n8n developers on reliability more than on how many nodes they can connect.
A practical checklist:
- Can they explain the dedupe/idempotency rule?
- Do they have a clear credential boundary and least-privilege plan?
- What happens on partial failure: source succeeds, destination fails?
- Are retries/backoff explicit, or just hidden in node defaults?
- Is there an audit log row or execution summary a non-developer can inspect?
- Can another developer understand the workflow without a 1-hour walkthrough?
- For AI steps, do they force structured output and define what happens on low confidence?
A good trial project is one narrow workflow: one trigger, one routing decision, one destination, logging, and a runbook. If they cannot make that clean, the bigger stack will get fragile fast.
If useful, I can also do a small paid audit/scoping pass on one current workflow and return a written risk map + first fix plan.
Best,
Brian Du
duyonggan@gmail.com
Hi Emma,
Regarding your questions, here is my two cents:
If you are developing complicated systems such as CRM sync, lead routing, and AI agents in between, then I would say that it is more than the n8n proficiency but more a system or platform builder/designer. The candidate should know the three things well:
  1. Technical capability (or limit) of n8n: so that he/she knows which node to use and what options to turn on/off. You could ask the candidate about the most sticky issue or challenging requirement addressed ever, and ask about the chain of thought to observe how the candidate deals with the issue. As to custom node I think that it is a very specific scenario (I just built a set of 4 custom nodes) and less likely a flag for n8n proficiency.
  2. gitops and devops of n8n. Previous replies mentioned a lot of gitops, DLQ, audit trail, rate limit, etc. Besides these I am recently building automated workflow testing which will bootstrap a clean, repeatable n8n env with specific version of workflow/credentials/data tables loaded from git and then run the test script via playwright. And to operate production grade n8n you will also need the observability. It might be too much for a pure n8n developer, but at least he/she shall know that your n8n will also need these to ensure the reliability.
  3. Domain knowledge. While people mostly have basic concepts about CRM, ERP, etc, when building a system that interacts with CRM or ERP it is often not enough to just know some basic ideas. Here the domain means not only the technical domain such as what an CRM does but also the industry that your CRM operates in.
Yes the discovery/audit phase is the standard practice. The key point is that this phase shall produce something tangible instead of just brainstorming without conclusion. For example integration map, risk list, quick-win backlog, etc.
Upwork and freelancer.com are overly-crowded from my observation. Referrals and paid test projects would be more practical.
A useful way to filter n8n developers is to ask for evidence around reliability, not only screenshots of a canvas.
Strong signals I would look for:
  1. Workflow architecture
    They should be able to explain when to split logic into sub-workflows, how state is passed between steps, and how the workflow behaves if one external API is slow, down, or returns partial data.
  2. Error handling and observability
    For ongoing CRM syncs, lead routing, and AI-agent workflows, ask for examples of retries, dead-letter queues, manual review paths, run logs, alerting, and idempotency. This matters more than the number of nodes.
  3. Boundary between deterministic logic and AI
    A good AI automation builder should not send every decision to an LLM. They should use deterministic rules where correctness matters, and LLMs for classification, extraction, drafting, or fuzzy reasoning where they add value.
  4. Discovery phase
    For mixed well-defined and exploratory needs, I would start with a paid discovery/audit. The output should be a process map, risk list, priority backlog, data/API inventory, and a first production workflow candidate. That prevents both sides from guessing the scope.
  5. Practical test
    Instead of a generic interview, give a small test: one intake source, one routing decision, one CRM or sheet update, one error path, and one human approval step. Ask them to document how to operate and debug it.
I build this type of AI/n8n automation around production constraints: inputs, validation, retries, human approval, logs, and handoff docs. If useful, I’m happy to share how I would structure a discovery/audit for your stack.
Jetty Lee
