Loop in flow
problem in loop, i get error, i put smth in a wrong order in the flow I suppose.
Node was not executed
The execution took a different path and didn’t reach this node. This typically happens with conditional nodes like If or Switch
The execution took a different path and didn’t reach this node. This typically happens with conditional nodes like If or Switch.d output. →
  • Operating system: windows 10
hi @insta_crawler , good morning!
The main error is in the logic of Loop over items / Split in Batches.
the final output of the Loop over items is empty.
Output 1 is not connected to anything. So when the loop ends, the flow ends there.
Check the telegram too, because it seems strange to me.
Hi @insta_crawler
Right now you are doing this
What about changing to this
or this
Code node produced no output data, hence everything is being dropped
