I don’t have errors, I need to know how it works
Please share the workflow
I want to write the resulting ip and “malicous” attribute from each httprequest in misp. It works, but only for the first IP on the first item. I don’t know how to iterate through the structure, because it is a list of arrays of arrays?? I am very confusied. The Splite node didn’t work and I tried with the code node, but I failed, because I don’t know how to get access to the values.
The structure:
- n8n version:
- Database you’re using (default: SQLite):
- Running n8n with the execution process [own(default), main]:
- Running n8n via [Docker, npm, n8n.cloud, desktop app]:
