Loops and String compare
I want to exec a python script that outputs a string, than I want to compare this string to the previous output (for example 60 seconds apart). If the strings are the same do nothing, if the strings are different then send a signal and update the previous string with the new one.
No errors, just that the loop does not work.
After the wait it is always faster the “previous data” node, therefore the exec is not run again.
  • n8n version: 1.97.1
  • n8n EXECUTIONS_PROCESS setting (default: own, main): own, main
  • Operating system: Ubuntu x64
Hi @LorenzoZappa
Here’s a workflow that loops correctly. Replace the mock code step with your execute step and it should work for your data.
:heart:If this response helped you, please click the heart to show that it is useful
:white_check_mark:If this response solved your issue, mark it as the solution to help the community
