I’m using n8n, and I lose data every time I use the command “sudo docker compose down.”
Here’s my docker-compose.yml file:
version: "3.7"
services:
caddy:
image: caddy:latest
restart: unless-stopped
ports:
- "80:80"
- "443:443"
volumes:
- ${DATA_FOLDER}/caddy_data:/data
- ${DATA_FOLDER}/caddy_config:/config
- ${DATA_FOLDER}/caddy_config/Caddyfile:/etc/caddy/Caddyfile
n8n:
image: n8n-custom
restart: always
ports:
- 5678:5678
environment:
- N8N_HOST=${SUBDOMAIN}.${DOMAIN_NAME}
- N8N_PORT=5678
- N8N_PROTOCOL=https
- NODE_ENV=production
- WEBHOOK_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
- GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
- NODE_FUNCTION_ALLOW_EXTERNAL=module1,module2
volumes:
- ${DATA_FOLDER}/local_files:/files
- ${DATA_FOLDER}/.n8n:/home/node/.n8n
- /home/n8n/code:/home/n8n/code
volumes:
caddy_data:
external: true
caddy_config:
My .env file
DATA_FOLDER=/home/n8n/n8n-docker-caddy
DOMAIN_NAME=xxx.yyy
SUBDOMAIN=n8n
GENERIC_TIMEZONE=Europe/Berlin
[email protected]
My Dockerfile to build n8n-custom image:
FROM n8nio/n8n:latest
USER root
RUN apk add --update python3 py3-pip
RUN apk add \
build-base \
freetds-dev \
g++ \
gcc \
tar \
gfortran \
gnupg \
libffi-dev \
libpng-dev \
libsasl \
openblas-dev \
openssl-dev
RUN npm install -g require
RUN npm install -g humanparser
My data folder’s permission:
n8n@n8n-test:~/n8n-docker-caddy$ ls -l -a
total 48
drwxrwxrwx 7 n8n n8n 4096 Aug 21 04:20 .
drwxr-x--- 7 n8n n8n 4096 Aug 21 03:21 ..
-rwxrwxrwx 1 n8n n8n 643 Aug 14 08:40 .env
drwxrwxrwx 8 n8n n8n 4096 Aug 11 02:44 .git
drwxrwxrwx 2 n8n n8n 4096 Aug 21 04:41 .n8n
-rwxrwxrwx 1 n8n n8n 317 Aug 21 03:59 Dockerfile
-rwxrwxrwx 1 root root 1082 Aug 11 02:44 LICENSE
-rwxrwxrwx 1 root root 779 Aug 11 02:44 README.md
drwxrwxrwx 3 n8n n8n 4096 Aug 11 02:44 caddy_config
drwxrwxrwx 3 n8n n8n 4096 Aug 11 02:44 caddy_data
-rwxrwxrwx 1 n8n n8n 865 Aug 21 03:41 docker-compose.yml
drwxrwxrwx 2 n8n n8n 4096 Aug 11 02:44 local_files
I noticed that no files are saved in the /home/n8n/n8n-docker-caddy/.n8n folder (using the ls -a command), even though I’ve created an account and generated flows. Could this be the reason for the data loss?
Thank you for your assistance.
- **n8n version: 1.1.1
- Database (default: SQLite):
- **Running n8n via (Docker, npm, n8n cloud, desktop app): docker
- **Operating system: Ubuntu 22.04.2 LTS (GNU/Linux 5.15.0-71-generic x86_64)
