Is it normal to have a manual execution still running and not be able to stop it ?
And this is weird, I have executed other manual executions and “non manuals” ones for this workflow, but they don’t appear in the history, there is only this line.
Strange. It looks like a network issue. Apparently, the message which does get sent via EventSource gets lost for some reason. So the Editor-UI is not aware that the execution is finished already.
In one of the next versions the execution ID gets unified (the same for past and active executions) it will then be easier to recover from issues like this and get the correct status from the backend.
