Many strange errors occurred when deploying n8n using docker. Does anyone know what the situation is?
The logs show a large number of repeated errors.
n8n  | Client version 1.14.1 is incompatible with server version 1.16.0. Major versions should match and minor version difference must not exceed 1. Set checkCompatibility=false to skip version check.
no
  • n8n version: 1.120.4
  • Database (default: SQLite): sqlite
  • Operating system: debian13
Hi @shouchi_migari !
Your workflow is OK, it has nothing to do with this “errors” warnings.
It s a gap between versions of n8n client/server.
In your docker-compose.yml file :
services:
n8n:
image: docker.n8n.io/n8nio/n8n:1.16.0
\# ... your other settings ...
There actually is the issue.
Thank you, my compose file is as follows. It only has one container, and I don’t know how this caused the version difference between the client and the server.
  n8n:
    image: n8nio/n8n:latest
    container_name: n8n
    restart: unless-stopped
    ports:
      - 10.0.0.2:30009:5678
    volumes:
      - /var/run/docker.sock:/var/run/docker.sock
      - .//home/node/.n8n
      - ./download:/home/node/download
      - ./rag-files:/data/files/rag
    depends_on:
      initContainer:
        condition: service_completed_successfully
    environment:
      - NODE_ENV=production
      - N8N_RUNNERS_ENABLED=true
      - N8N_PROXY_HOPS=1
      - N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
      - NODE_FUNCTION_ALLOW_BUILTIN=*
      - NODE_FUNCTION_ALLOW_EXTERNAL=*
      - DB_SQLITE_POOL_SIZE=5
      - EXECUTIONS_DATA_PRUNE=true
      - EXECUTIONS_DATA_MAX_AGE=72
      - EXECUTIONS_DATA_PRUNE_MAX_COUNT=10000
      - NODE_OPTIONS=--max-old-space-size=4096
      - N8N_BLOCK_ENV_ACCESS_IN_NODE=false
      - N8N_GIT_NODE_DISABLE_BARE_REPOS=false
    healthcheck:
      test: ["CMD", "sh", "-c", "wget --quiet --spider --tries=1 --timeout=10 http://localhost:5678/healthz || exit 1"]
      interval: 30s
      timeout: 10s
      retries: 3
      start_period: 30s
That .//home/node/.n8n line is almost certainly not what you intend.
It should map a host directory to /home/node/.n8n or where you have it.
Definitely is an old image and that’s why that errors.
You gave to do it properlywith Docker.
P .S i still use npm(will be deprecated later), but Docker only when I have to “move” out lol, and honestly can easily bring headaches.
I found that this issue only occurs when running this part.
I found the issue: my Qdrant service version is v1.16.0, but n8n’s Qdrant Vector Store is 1.14.1, which caused an error. Thank you for your help.
Actually it was the node version and not n8n instance.
Glad that is solved!
:slight_smile:
