Marketing Automation
Hi everyone,
I’m working on setting up a monthly marketing automation using n8n. The goal is to deliver fresh media packages to a group of agents every month basically a set of updated content they can use to promote a product. I’m looking for advice on the best way to structure this automation in n8n. If anyone has experience with recurring content delivery workflows or similar setups, I’d appreciate any pointers!
Thanks a lot!
Have you taken a look through the template library? Discover 6542 Automation Workflows from the n8n's Community
That would be the best place to start for reference.
Other than that my general advice would be to break the problem up in to the smallest possible components and build it iteratively.
