MCP Error: "Received tool input did not match expected schema"
Yo guys, I built an MCP that connects to Semrush for keyword research. It works successfully but there is a problem.
When I connect it to an AI Agent node with Claude, the AI Agent node gives ts error: “Received tool input did not match expected schema”.
Example tool output:
    "response": [
        "tools": [
            "name": "domain_overview",
            "description": "Get comprehensive domain analysis including organic keywords count, estimated traffic, domain ranking, and basic SEO metrics",
            "schema": {
              "type": "object",
              "properties": {
                "domain": {
                  "type": "string",
                  "description": "Target domain to analyze (e.g., example.com)"
                "database": {
                  "type": "string",
                  "description": "Geographic database for analysis (default: us). Examples: us, uk, de, fr, tr"
              "required": [
                "domain"
              "additionalProperties": false,
              "$schema": "http://json-schema.org/draft-07/schema#"
            "name": "keyword_analysis",
            "description": "Comprehensive keyword analysis including search volume, keyword difficulty, CPC, competition level, and related keyword discovery",
            "schema": {
              "type": "object",
              "properties": {
                "keyword": {
                  "type": "string",
                  "description": "Target keyword to analyze"
                "database": {
                  "type": "string",
                  "description": "Geographic database for analysis (default: us). For Turkish use: tr"
                "include_related": {
                  "type": "boolean",
                  "description": "Include related keywords discovery in the analysis (default: false)"
                "related_limit": {
                  "type": "number",
                  "description": "Number of related keywords to return (max 50, default: 10)"
              "required": [
                "keyword"
            "name": "competitor_analysis",
            "description": "Discover organic competitors and analyze competitive landscape with shared keyword analysis",
            "schema": {
              "type": "object",
              "properties": {
                "domain": {
                  "type": "string",
                  "description": "Target domain for competitor analysis"
                "database": {
                  "type": "string",
                  "description": "Geographic database for analysis (default: us)"
                "limit": {
                  "type": "number",
                  "description": "Number of competitors to return (max 50, default: 20)"
              "required": [
                "domain"
            "name": "traffic_analytics",
            "description": "Advanced traffic analysis including organic keywords performance, top pages, and traffic insights",
            "schema": {
              "type": "object",
              "properties": {
                "domain": {
                  "type": "string",
                  "description": "Target domain for traffic analysis"
                "analysis_type": {
                  "type": "string",
                  "description": "Type of traffic analysis to perform"
                "database": {
                  "type": "string",
                "limit": {
                  "type": "number",
                  "description": "Number of results to return (max 100, default: 20)"
              "required": [
                "domain"
            "name": "related_keywords_discovery",
            "description": "Advanced related keyword discovery tool for content expansion, including semantically related terms, question keywords, and long-tail variations",
            "schema": {
              "type": "object",
              "properties": {
                "seed_keyword": {
                  "type": "string",
                  "description": "Primary keyword to find related terms for"
                "match_type": {
                  "type": "string",
                  "description": "Type of keyword matching to perform"
                "database": {
                  "type": "string",
                  "description": "Geographic database for analysis (default: us). For Turkish keywords use: tr"
                "volume_filter": {
                  "type": "object",
                  "additionalProperties": {},
                  "description": "Filter keywords by search volume range"
                "difficulty_filter": {
                  "type": "object",
                  "description": "Filter keywords by difficulty range (0-100)"
                "limit": {
                  "type": "number",
                  "description": "Number of related keywords to return (max 100, default: 25)"
              "required": [
                "seed_keyword"
How can I fix this issue? If you need any other information, just let me know
btw, here is the MCP server: @ilker10/semrush-mcp - npm
