I am experiencing an issue where connecting the Postgres Chat Memory node in my n8n workflow leads to an incorrect output from the CheckerAI (LangChain AI Agent). When I remove the memory node, the AI provides the expected and correct output.
Expected Behavior:
- The AI should correctly process the compliance checks and return accurate warnings.
- Memory should enhance context retention without modifying the logic of the AI’s response.
Actual Behavior:
- With memory enabled, the AI incorrectly adds extra warnings (e.g.,
Truck weight exceeds maximum allowed limit
even when it shouldn’t). - With memory removed, the AI returns the correct set of warnings
Outputs:
Incorrect Output (with Memory)
"output": {
"warnings": [
"Restricted commodity: alcohol",
"Missing required permit: hazmat",
"Truck weight exceeds maximum allowed limit"
Correct Output (without Memory)
"output": {
"warnings": [
Environment Details:
- n8n Version: 1.73
- Database Used for Memory: Postgres
- Deployment: Self-hosted
